LO3 to ZZ383 Swap retaining TBI setup
Old Jul 25, 2005 | 09:20 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I want to swap my poor little 305 for that GM ZZ383 Crate motor. I have no experience with TBI, and wanted some help getting a parts list together. I would like to order everything I need in one shot from summit, assemble it on an engine stand, drop it in, hook it up, and drive away. If summit part #'s could be included, that would be great. I'm assuming I would have to use a TB and manifold from a 454.
What will I need to make my TBI work on a ZZ383 using the stock computer and harness?
Old Jul 25, 2005 | 09:30 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Ain't gonna happen, your gonna need lots of tuning for an engine of this sorts. By tuning I mean hands on DIY tuning, mail order won't cut it.
I don't mean to shoot down your project, just merely informing you of what it takes to make power with TBI. Keep asking questions and we'll get ya squared away.
Old Jul 25, 2005 | 12:06 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
You will be looking at a few bucks- not sure what you have done to the car in terms of exhaust, suspension and traction, but those will need to be addressed.
Tuning will also be important as BMmonte points out.
I am in the middle of what you are considering, except I installed a 6 speed to boot and have taken care of the exhaust, suspension, traction and tuning on a previous buildup.
Keep at it- but be sure to bring your wallet.
S-D
https://www.thirdgen.org/techbb2/sho...hreadid=307640
Old Jul 25, 2005 | 05:01 PM
jimp2001's Avatar
Engine: LO3 305 TBI
I am aware of the tuning I'm going to have to do, and I am researching on how to burn my own PROM...
What should I do as far as a manifold, TB, injectors, fuel pump, etc? If I have the parts I could put it all together, but I dont know what will fit.
I really want to go TBI, but if it's going to be a major pain in the ***, I'll just go with a carb. (I really, really want TBI to stay)
As far as exhaust, everything on my sig is whats going on the car, nothing more, nothing less.
Old Jul 25, 2005 | 05:29 PM
ben73's Avatar
Re: LO3 to ZZ383 Swap retaining TBI setup
You won't be using the manifold from the 454!
I'd suggest a single plane manifold. There are threads here where guys have experimented with them. If you do a search, you will find which ones they used and fit under the hood without problems.
Old Jul 25, 2005 | 06:05 PM
jimp2001's Avatar
Engine: LO3 305 TBI
lol i was thinking injectors and typed manifold... haha!
yeah im looking to keep a stock appearance, so it's got to clear a stock hood if possible.
at worst I'll slap an "SS" hood on it
Old Jul 25, 2005 | 06:16 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Why does that car look so familiar?
If you go with a manifold for a carb, you're going to have to use an adapter plate for the TBI. Those two things will really be pushing your stock hood clearance levels.
You'll most likely have to use a drop-based housing with a 14x2 filter, but I'm not totally sure. Might just be easier to bore out an Edelbrock TBI to 2"
Old Jul 25, 2005 | 07:37 PM
jimp2001's Avatar
Engine: LO3 305 TBI
so i need:
fuel pump
454 TB & injectors
manifold
tons of tuning
is it me or does this sound too easy? what am i missing?
Old Jul 25, 2005 | 08:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Most people don't find tuning to be easy. Get started on your car NOW while it's stock, that way you have the hang of things before you do the swap.
Old Jul 25, 2005 | 08:17 PM
jimp2001's Avatar
Engine: LO3 305 TBI
My next investment is prom burning tools.
If anyone would like to add someting, I could really use all the advice I can get for this conversion.
Old Jul 25, 2005 | 08:21 PM
ben73's Avatar
I have to agree with what BMmonteSS says above.. Start tuning and learning on your current motor first..
I have a TBI 383 and while tuning wasn't really difficult, i imagine it would have been for a first timer...
Old Jul 25, 2005 | 09:28 PM
Car: 91 RS
Engine: 350 TBI
Yes, computer tuning a TBI sucks.
Old Jul 25, 2005 | 09:49 PM
jimp2001's Avatar
Engine: LO3 305 TBI
do you think a TBI ZZ383 can bring me into the mid 12's?
Old Jul 25, 2005 | 10:10 PM
Car: 91 RS
Engine: 350 TBI
If you build it right and can actually not roast your tires all the way to 30mph, sure.
I don't know, maybe 400hp and 400lb/ft might get you there. If you're going to use nitrous, then it won't be a problem at all.
Old Jul 25, 2005 | 10:33 PM
jimp2001's Avatar
Engine: LO3 305 TBI
Acording to GM's specs the motor makes 425hp,450ft/lbs using a GM single plane intake, P/N 12496822 and a 750 CFM Demon carburetor with mechanical secondaries. Test header specs are: 1 3/4" primaries, 33 inches long with 4-inch collectors.
GM dual plane intake P/N 12366573 may be used for hood clearance on the ZZ383/425, but results in a decrease in peak horsepower of approximately 15-20 horsepower.
Old Jul 26, 2005 | 12:45 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Keep us posted sounds pretty awesome
Old Jul 29, 2005 | 03:50 PM
DM91RS's Avatar
Car: 91 RS
ben73
Red/Red 84 Vette. 383 Crossfire 12.48 111.6mph
customblackbird
Aug 15, 2021 10:16 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
Street Lethal
Aug 13, 2015 08:28 PM
