Wire harness connector issue
Old Aug 3, 2005 | 11:51 PM
Dioak88GTA's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
Transmission: 700R-4
i've got a question for ne one that can give me an answer...does ne one know where i could get gm engine harness connects by themselves? does ne one make those anymore?....i know i could get a junkyard car but the junkyards around my are SUCK! never any 3rd gens.. ne ways i just need to find a place that sells some connectors. ne body got a clue it would help out a lot! thx
Old Aug 6, 2005 | 04:56 PM
Vader's Avatar
Pep Boys, AutoZone, Advanace Auto, and their clones may have them. Rockauto.com has them. Any real parts store that reps the Standard Motor Products line has them or can order them for you. They are still available.
Old Aug 7, 2005 | 12:46 PM
Ollie8974's Avatar
Car: 1979 Zcode TA
Engine: 220hp 400ci Building a EFI 455
Transmission: 4 speed
On the same subject, what about the pins to repair a wire that is broken off right behind the plug. I have a TPS and a IAC plug, Standard Motor Parts number S 551 and S 619 that I need some repair pins. The catalouge show the plugs and pins but it does not indicate what pins go to which plugs.
Old Aug 8, 2005 | 10:24 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
The TPS and IAC connectors both use the same pins. They are weatherpack male terminals.
Old Aug 8, 2005 | 02:31 PM
Ollie8974's Avatar
Car: 1979 Zcode TA
I dont have a problem with the weather pack pins. This is the style plug I need replacment pins for. Standard Motor Products IAC part number S 619
Old Aug 8, 2005 | 02:32 PM
Ollie8974's Avatar
Car: 1979 Zcode TA
And this style TPS. Standard Motor Products part number S 551
Old Aug 8, 2005 | 08:05 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
What are those from? They don't look like a TPI TPS or IAC plug to me...
Old Aug 9, 2005 | 01:48 AM
Ollie8974's Avatar
Car: 1979 Zcode TA
Go to http://www.smpcorp.com/
parts lookup /part number lookup for S-551 and S-619 for a list of cars
Old Aug 9, 2005 | 11:23 AM
S10Wildside's Avatar
Those connectors are used with the newer V6 engines and a lot of applications beyond 1990. The terminals used in the TPS connector pictured above can be used in the IAC connector pictured. The IAC connector pictured (also the same connector as the TPI small cap distributor) had a redesign that put four slots in the bottom and different terminals were used. Before the redesign, the connector used the TPS (pictured) style terminals. However, TPS style terminals can be used in the newer style IAC connector.
I build new wiring harnesses and have these pieces. I can't advertise on these boards, but you can contact me privately if you need some connectors/terminals.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
