Silver Rides Again
Old Aug 11, 2005 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Silver Rides Again
Some polish.
JamesC
Old Aug 11, 2005 | 06:46 AM
JamesC's Avatar
New motor.
JamesC
Old Aug 11, 2005 | 06:47 AM
JamesC's Avatar
Spiffed up interior.
JamesC
Old Aug 11, 2005 | 07:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've always liked your car.
Old Aug 11, 2005 | 10:32 AM
lxcamaroxl's Avatar
Car: 92 Camaro (R)eally(S)tock
Transmission: Auto 700r4
NIIICE
New motor!!!!
interior
Old Aug 11, 2005 | 10:34 AM
Parrydise7's Avatar
DAMN!!!!!
Old Aug 11, 2005 | 11:35 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
That looks very very good.
Old Aug 11, 2005 | 12:03 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
those wheels look wicked with the silver... nice car!
Old Aug 11, 2005 | 01:44 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
Nice work
Engine swap looks very clean.
Although I miss the Dual Snorkel aircleaner. Might wanna remove the plastic intake ducts.
Old Aug 11, 2005 | 02:54 PM
85_ZED28's Avatar
Car: '85 Z28
Very nice!! What are the specs on the new engine?
Old Aug 11, 2005 | 04:14 PM
JamesC's Avatar
Many thanks for the kind comments.
Engine specs:
Bore x stroke: 4.00x3.48
HP & Torque: 330 hp @ 5,000, 380 lb-ft @ 3,800
Compression: 9.1:1
Block: Cast-iron four-bolt main, one-piece rear seal
Crank: Nodular cast iron
Connecting rods: Powdered metal forged steel
Pistons: Cast aluminum, dished, 5/64-inch rings
Camshaft: 212/222 degrees @ 0.050, 0.435/0.460-inch lift
Heads: Vortec iron, 1.94/1.50-inch valves
Rocker arms: Stamped steel, 1.5 rail type
Intake: Dual-plane aluminum
Carb: Holley 600 cfm, vacuum secondary
I enjoy the stock appearance of the car, but here's the rest of the story:
GM lightweight flywheel, CenterForce II clutch kit, Hooker headers, Catco hi-flow cat, Hooker cat-back, GM dual electric fans, T5 with B&M Ripper and Hammer shifter, Energy Suspension motor, tranny, secondary crossmember, torque arm, bump stops, and tie-rod boots, Prothane A-arm bushings, Global West steering box brace and subframe connectors, Hotchkis tie-rod sleeves, Spohn 1LE front brake kit, PBR rears, Earl's braided-steel brake lines, 1LE sway bars with GM poly end links and Top-Down Solutions greaseable 36mm front and Energy Suspension greaseable 24mm rear bushings, 1LE aluminum drive shaft, Edelbrock torque arm, Spohn lower control arms and panhard, Summit differential cover, 1LE 10-spoke aluminum space-saver spare. Lear/Seigler Conteur driver’s seat, overhead console, 145 mph speedo, MBA billet pedals, Alpine CD player and Kenwood speakers, Grant Signature Series steering wheel with black billet sleeve and silver 'Camaro' horn button, and **** mirror (auto dimming, temp, compass). Sylvania Silverstars. Propart clear side markers.
JamesC
Old Aug 11, 2005 | 07:55 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
is it lowered at all?
if its not lowered.lower it,get irocs in 18s and that would be a sick car
Old Aug 11, 2005 | 08:24 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Such a beautiful car! What kind of seats are those?
Old Aug 12, 2005 | 06:35 AM
JamesC's Avatar
No, the car's not lowered. I flirt with the idea from time to time, but there are too many issues that I personally don't like, especially the possibility of dragging. The Hooker 2055 y-pipe drops about an inch below the k member as is.
The driver's seat is a Lear/Seigler Conteur, found in some early 80's Camaros. It has thigh, seat, seat back, and lumbar adjustments. It also sits on a six-way electric track.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Linson
Sep 21, 2015 01:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
