mass airflow voltage
Old Aug 30, 2005 | 08:06 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
Transmission: 700r4 w/ b&m shift kit
i run a diagnostic test on my camaro and it says i have a code 33 which means the voltage is too high in the maf. now i looked in the book and it says it has an excess of 35 or 40 gr/sec of air to have a code 33 but on the diagnostic tool it says its only 13gr/sec on the sensor. i was originally going to just replace the maf but is it the maf or something else with this error?
Old Sep 2, 2005 | 07:59 PM
Vader's Avatar
Check for low TPS voltage.
Old Sep 3, 2005 | 03:31 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
how do i do that?
Old Sep 3, 2005 | 05:37 PM
Vader's Avatar
First, I am presuming that this is regarding the '88 IROC in your signature, and although it has a " '91 350", it still uses the '88 ECM and wiring.
More often that not, a DTC 33 is caused or contributed to by a TPS voltage that is too high for a given throttle angle. This can occur if the TPS has been installed or adjusted incorrectly, or especially if the throttle stop screw has been inadvertently adjusted. Since the ECM is supposed to control the idle RPM through the IAC, there should seldom be a need to adjust the throttle stop.
Using a DVM, you can back-probe the 'A' and 'B' terminals (black and blue wires) of the TPS connector with the ignition turned ON. The voltage reading should be less than 0.060VDC. Ideally, it should be at 0.54VDC.
Another thing that can cause the error on your installation is operating a 350 wiht an ECM program written for a 305 TPI. The ECM expects less intake air to flow at any given RPM and/or throttle angle. Any hints about the engine/ECM/PROM installation?
Old Sep 5, 2005 | 09:46 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
maf problem making progress but still need help
so i probed the mass airflow sensor in the back (being the green wire and the black one) of the connection and i got around 2.5 volts both when the car is "on" and when it is idling. is that normal? if its not then what do i do?
Old Sep 9, 2005 | 01:55 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
tps adjustment
i've been reading alot about code 33 being wut i have due to a messed up tps. im gettin 2.5 volts at the maf at idle so im going to adjust the tps. now how do i do that and am i reading the right voltage? do i need to probe the tps or just from the maf?
Old Sep 9, 2005 | 09:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I believe that there is a tech article on this issue (TPS adjustment),,, it really does not have anything to do with the MAF sensor. At idle the TPS voltage should be around 0.54V factory (check the article for the correct voltage). For better throotle response, you can try 0.60V to 0.64V... I think that I'm at 0.62V now.
Old Sep 10, 2005 | 03:19 PM
Vader's Avatar
Idling, the MAF analog output signal should be around 0.800-0.950 VDC.
A reading of 2.5VDC means one of a few possibilities:
1. The engine is "idling" at about 5,000 RPM, drawing in about 128 g/S of intake air (not likely);
2. The MAF burnoff relay/function is faulty, and the burnoff lead to the MAF is inadvertently energized. You can eliminate that possibility by reading voltage at the dark blue wire at the MAF with the engine running. There should be nearly 0 volts. Anything more is a problem.
3. More likely, it means that the installed MAF is the FM type and not the analog type. The FM MAF sensor outputs a 5V P-P square wave signal at varying frequencies. The duty cycle of the square wave is designed to be 50%, so most meters will average that signal on a DC voltage scale to 2.5VDC - just what you are reading.
Read the part number on the MAF and report back. I'm curious. Very curious.
Old Sep 10, 2005 | 03:30 PM
Vader's Avatar
I just tried to track down your problem history.
This may be the answer:
https://www.thirdgen.org/techbb2/sho...hreadid=317351
Originally posted by emayetete
would a 1986 v6 camaro mass aifrlow sensor work in my 1988 5.7 camaro?
Originally posted by 8Mike9
Hmmn, good question, but I can't answer...
But, knowing that 86-89 V8 MAF's are the same, you might have luck comparing part numbers on partsamerica.com or autozone.com to see if the same number is listed for your V6.
I can answer. They are NOT the same. The V-6 MAFs are the aforementioned FM type. The V-8 MAF in 1985 was the FM type. From 1986-89, the V-8s used the analog (Bosch) MAF . If you installed a V-6 MAF on a V-8 ECM and system, you've found the problem.
Old Sep 11, 2005 | 02:00 AM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
no its still a bosche in there right now. i havn't checke the burn off relay yet so i'll probe it tomorrow. see if its 0 volts at the blue wire. if its 0 volts then im going to just replace the mass airflow sensor. do u think that would be a good course of action?
Old Sep 11, 2005 | 02:25 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i would adjust the TPS as before recommended and if i replaced anything, it would be the MAF power and burn-off relays. i used to have te same problem. like vader, i doubt that it is the MAF sensor.
Old Sep 11, 2005 | 11:11 AM
Vader's Avatar
Did you find the part number on the MAF yet? I'm guessing that it isn't the same as this one:
Old Sep 11, 2005 | 03:49 PM
emayetete's Avatar
Car: 1988 iroc
Engine: '91 350
0280213009
10055877
it looks exactly the same, those are the numbers on the bottom of the maf.
Old Sep 11, 2005 | 04:04 PM
87zjeff's Avatar
ok, then maybe it is the maf sensor. i just checked my factory one and it matches the one vader is showing.
i just went and checked a parts sight and they list those cast numbers as a borg warner new one.
Old Sep 11, 2005 | 05:46 PM
1FSTZ28's Avatar
Car: 1989 Camaro IROC Z28
Engine: 350 Stealth Rammed
I am having the same problem. My car continues to show a Code 33. I just recently got the Holley Stealth Ram Intake installed and i got a code 33. So i replaced the MAF Sensor, MAF Sensor Relay, MAF Sensor Burn-off relay, TPS (and had it set), IAC. I am still getting a code 33. The check engine light will come on then go off about 5-10 seconds later. I have had nothing but problems with my car since i got the HSR installed. I have no idea if the MAF is the problem or if its something else.
Old Sep 11, 2005 | 05:49 PM
Vader's Avatar
That number should be a valid analog MAF. If you have no voltage at the burnoff terminal and are reading 2.5VDC at the analog output (with a reliable meter) the MAF is toast.
Old Jul 21, 2010 | 01:22 PM
rednekwizard's Avatar
Car: 1986 Z-28
Transmission: 700-R4
Re: mass airflow voltage
I have a 1986 camaro Z-28 with a 350 tuned port(really not sure what car the engine came from), I keep getting the 34 code so I took the maf out and ran the part numbers(0280213009), also the connector is busted on the maf sensor, the only part that comes up is for bosch.
Every maf sensor i have looked at for my car has a three pin connector but the bosch that is on it and the harness in the car is five pin.
Elephantismo
Feb 13, 2019 12:51 AM
antman89iroc
DIY PROM
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
327IROC85
Sep 23, 2015 12:11 AM
