Q about Power Adder Hitting 13's
Old Oct 20, 2005 | 09:08 AM
FBoDyV85's Avatar
Car: 89 IROCZ Camaro
Engine: 350 w/ Boltons
As of now i have an 89 camaro. Stock 350 TPI with 3" headers back exhaust. Hooker 2055's into a strait pipe into Hooker Comp Catback. Stockairbox with ram air upgrade.
Will 3.73's get me there?
any advice is helpful. try not to flame.
-Steve-
Old Oct 20, 2005 | 04:21 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Nope they wiill take you a little further out of your powerband or so Iv'e learned. They wouldn't help unless you have 2.73's or something
Old Oct 20, 2005 | 04:42 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
3.5x's or 3.2x's would be better. 3.73's are probably a little too much for your combo, if your running an auto
Old Oct 20, 2005 | 07:12 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
unless your awesome at launching, get some 3.27's (3.23 with 10 bolt)
Old Oct 20, 2005 | 07:25 PM
FBoDyV85's Avatar
yea runnin on 2.73's now was just wondering what kinda setup would work out .. any reason why i should only get 3.27's?
Old Oct 20, 2005 | 08:10 PM
mean57's Avatar
Car: 87 gta
well, with my 3.27 in my nine bolt i cross the line at about 4600
rpm. i will probably in the future switch to a 3.45 or so to pull me through the traps at say 51-5200 rpm. my tpi is modded so will pull just a hair longer than stock set-up.
Old Oct 20, 2005 | 08:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
what about a power adder? ur adding jsut gears not a power adder
my 3.27's pull me thru the line at around 4200rpms....
3rd gear to 4800rpms or so takes me to 110-115 mph
i would say, under a perfect launch which can be done, on decent street tires, u can cut a bottom 1.9 60 foot and hit a high 13
else ur gonna need a torque converter and maybe some bolt ons.
or the right suspension mods will also help... i think my 1.8's on street tires are pretty much due to the shocks/springs
if u put in some adjustable shocks and drag springs, u can launch very hard off the line and get 13's
Old Oct 20, 2005 | 09:14 PM
FBoDyV85's Avatar
wut if i had a 2400 stall w/ 3.45's 13's ? =)
Old Oct 20, 2005 | 10:51 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
What brand of street tires are you using to cut 1.8 short times? Any other suspension mods?
BlueIroc-Z
Jun 9, 2019 03:22 AM
diana227vegas
Jul 8, 2016 12:27 AM
Orr89RocZ
Feb 13, 2016 10:04 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
