int lights
Old Mar 13, 2002 | 12:34 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
int lights
I have a 91 ta which the prev owner blew the dash lights out. I checked the fuse and it was to large so i think that something else was damaged because of this. When i check the fuse terms there is no power to it with or without the lights on. Has anyone had this problem? What is the next device in line to be fried when this is done any help is greatly app It sure is hard to drive at night when you live in the country
Old Mar 13, 2002 | 01:30 AM
2vmodular's Avatar
https://www.thirdgen.org/techbb2/sho...threadid=84346
https://www.thirdgen.org/techbb2/sho...threadid=12602
Old Mar 13, 2002 | 03:52 PM
91blkta's Avatar
part #
does anyone know any venders on line that sell the remote dimmer switch for the ta's I tried acdelco with no luck If you have any info that would be great trying to say away from dealership they love to get you coming and going if they can.
Old Mar 13, 2002 | 06:53 PM
91blkta's Avatar
found part
I found it at parts america if anyone needs to know it was under the ac part #
Its 28.00 plus shipping thanks to anyone that replied cant wait to see the lights again I always loved the ta red int lights
Old Mar 31, 2002 | 06:29 PM
91blkta's Avatar
Just wanted to thank all the help i rec'd on this problem I have lights once again and didn't pay a arm and leg thanx everyone for the links.
Old Apr 6, 2002 | 09:17 PM
blkform88's Avatar
I have the same problem. But did anyone's radio lights work, and then go out when the headlights were turned on?
Old Apr 9, 2002 | 11:34 PM
91blkta's Avatar
Is it a aftermarket radio?? If it is you may have a wire crossed check the dimmer wire to make sure its hooked to the right spot
Old Apr 10, 2002 | 10:21 AM
blkform88's Avatar
No, It's a stock stereo. I never touched any wires. One night I turned on my lights and the interior was blacked out. Sooner or later,I'm gota get behind the dash and see if I can figure this out. But the remote dimmer switch is my new leading suspect.
Old Apr 10, 2002 | 11:44 PM
91blkta's Avatar
Thats what i replaced and everything is functional now. mine was compleatly dead due to a short putting in a radio with to large of a fuse in the fuse cluster. I bought mine from parts america for about 28-30 after shipping. Mine was mounted above the fuse closer to the driver. just remove the lower dash and you will see what i mean.
Old Apr 12, 2002 | 08:45 AM
blkform88's Avatar
Thanks for the help. Im gonna get the dash off sometime soon and see what I can do. I posted before and no one mentioned the dimmer switch. I wonder If its shown in any wiring diagrams.
Old Apr 12, 2002 | 11:36 AM
2vmodular's Avatar
1985+ thirdgen firebirds have a "remote dimmer" setup. The common failure part is not the dimmer switch itself, but rather the dimmer transistor aka "remote dimmer". The part is well hidden in the dash, you only need to remove the drivers underdash panel and convience cluster to access it, you don't need to remove the entire dashboard from the car like one would for a heater core replacement.
1984 and prior firebirds do not have a "remote dimmer", nor do any thirdgen camaros (except possibly berlinetta). lights in such vehicles are dimmed by having a conventional variable resistor in series with the panel lights.
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
