iPOD integration??????Possible??????
Old Feb 25, 2007 | 01:52 PM
RPM WOT L 98's Avatar
I doubt that this is possible but I'm gonna throw it out there anyway.
Is it possible to wire an AUX input to a FACTORY '93-94 CD Player for use with an iPOD?
I know about the FM transmitters and the cassette tape adapters. This being a CD player I can't use the tape adapter and would rather not use the FM TXmitter if possible.
Just wanted to get some of your opinions.
Mark
RPM
Old Feb 25, 2007 | 08:01 PM
SS Ball3r's Avatar
if you hvae amps, then you could just do what i did and connect your ipod to the amps via headphone out to rca in cables. i used 2 of those and used a headphone splitter in place of a head uniot due to the fact that i am 17 and hvae no money at the moment, lol
it works pretty good. but then i have no radio now either, lol
Old Feb 25, 2007 | 08:43 PM
Camar0's Avatar
Car: 85' Z-28
Something like this? 3.5mm jack plugging into the headphones port on the iPod.
Old Feb 25, 2007 | 09:17 PM
Yeah that's what I am looking for. Does anyone make a kit for it or???
Old Feb 25, 2007 | 11:05 PM
88trans_am_gta's Avatar
Car: '88 gta
Engine: 350 tpi
um, idk if this helps, but they do make a fm tuner for the ipod. i use it in my car. its something like 30 bucks i think. might be easier buying that.
Old Feb 26, 2007 | 12:30 AM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I did it with my stock Delco Auto-Reverse tape deck, but with the CD player the proceedure would be different. I'll include the info I know about the tape decks, perhaps it'll help you formulate a plan of attack with your CD player.
On the delco tape decks, there are 5 wires going from the tape mechanism to the main board, the colors are Orange, White, Red/White, Brown, and Red.
Orange and white are right audio and left audio respectively. Red/White is Radio power, Red is tape motor power and Tape/Aux power is brown.
To add an audio in jack, you solder a headphone jack onto the orange and white wires, then run the ground lead to the chassis of the stereo. you can insert a blank tape into the deck and it will let you test the jack, you should be able to hear audio from your portable music player instead of the tape or radio.
your next step will be to add a switch to turn off both the Red and Red/White wires. I simply used a toggle switch, but there is a special headphone jack available that will also act as a switch when the plug for your player is inserted, if you prefer a cleaner look.
if you notice a loud pop from your speakers when you pause or skip forward, add a 100mf capacitor inline from your new auxillary jack's Left and Right input wires (one on each wire except ground), and that will fix the problem.
Ive never tried modifying the delco CD player, hopfully it's not much more difficult than the steps for the tape player. good luck with your project.
Old Feb 26, 2007 | 05:02 PM
mickstan's Avatar
Car: 1988 Eurosport VR
Engine: 2.8
Transmission: MXO 4-speed auto
Axle/Gears: 3.33
88KARRV6, your on the right track, but there is a MUCH better way to do it! I have the secret! I'm pretty sure it could also work on a CD radio. If you guys could post some pics of the radio with the top removed, I might be able to tell if it'll work. I'm pretty sure it works on a tape style up to '99. The ones that look like a um6, but the tape goes in the other way. And I know it works up to '89.
The way I do it, it has no switchs or adapters. Just like the one in the pictures except the plug is on a cord instead of in the face of the radio.
Plug 'n' play after its installed.
No evil-bay links allowed here, and I got one, so........PM me if your interested.
Old Feb 26, 2007 | 09:09 PM
Ok, so where does your system plug the ipod into? I don't have any pics of the radio with the top removed but here's one of the face so you can get an idea of which one I am working with.
Any help is appreciated, I'd like to be able to do this if practiacal.
Mark
RPM
Old Feb 26, 2007 | 09:24 PM
mickstan's Avatar
Engine: 2.8
Axle/Gears: 3.33
I'll bet that stereo WILL work. It looks the same on the outside as a um6, as far as the *****, and I'll bet the amp is right behind them.
The ipod plugs into a female stereo headphone jack, you'll need a 5 dollar 1 ft male to male headphone cord from radio shack to plug the ipod into the stereo. There is a photo of it in the "where do i put my ipod" thread.
PM me and I'll give you the link to my evil-bay auction.
Old Mar 1, 2007 | 08:03 PM
PM sent. Thanks
Old Mar 2, 2007 | 10:42 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
hey my last headunit had an AUX input where i could use my mp3 player with it (red and white ends into the aux input and the a headphone jack on the other side) that headunit had a bunch of problems so i bought another one off a guy for pretty cheap, but it doesnt have the AUX input so i cant use my mp3 player.. and the fm transmitter i have dosnt work very very because of my eception.. but what im asking is.. is there a way to add the aux input or something? i have input for a cd changer.. is there anythign i could add to get it?
sorry RPM WOT, not trying to hijack your thread or anything, i just thought this was the same thing you wanted to do, but i have an aftermarket headunit
Old Mar 2, 2007 | 07:41 PM
Hey, no problems! From what I have researched so far, if you have a newer radio with an CD changer input then you can get an adapter that will plug the mp3 player into the CDC port since that is basically an AUX port. I'll try to find that link for you.
Mark
BTW mickstan has the right idea here, currently working on finding out whether it will work on my CD player. I'll update the thread once we get that figured out. But his system is the best I've seen for a tape deck!
Old Mar 2, 2007 | 09:20 PM
Here's a link to one.
http://www.autotoys.com/x/catalog/WI...ES_p_5535.html
Google it and you can find a few more companies that make the adapter for the CD changer input.
Mark
Old Mar 2, 2007 | 10:35 PM
TheBandit's Avatar
Engine: Poncho 350
i love you :]... they have htem with regular headphone jacks right? for any kind of mp3 player? cause i dont have an ipod :P
Old Mar 3, 2007 | 01:48 AM
mickstan's Avatar
Engine: 2.8
Axle/Gears: 3.33
I went to the local pick-n-pull the other day, and "gently" openend up several radios. Saturns and other GMs up to about '03. The radios all look basicaly the same. There is a ribbon cable is common in all of them. Thats where the cord hooks into. This mod COULD work in a LOT of radios. But right now, I don't have the ability to test them all!
As far as aftermarket stereos....I have no idea at all if it would work.
Old Mar 7, 2007 | 11:49 AM
hot92z's Avatar
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
Im a big audiophile and hooking up an MP3 player to a newer headunit is a cake walk.
You need a stereo cable with a 3.5 connection (they are like 4 bucks at radioshack) plug the red and white to the back of the unit then plug the 3.5 end into your player and there you're done. If you have a tape player just get a tape adapter for like 10 bucks.
I suggest getting a stand alone headphone amp for the best sound quality and Rockboxing your Ipod and heading over to http://www.head-fi.org/
Old Mar 7, 2007 | 04:30 PM
mickstan's Avatar
Engine: 2.8
Axle/Gears: 3.33
Pardon my french, but tape adapters suck. And so do transmitters.
Old Apr 16, 2007 | 06:28 PM
Whoodoo's Avatar
Re: iPOD integration??????Possible??????
Here's what I did. Its extremely clean and when iPod isn't in, looks like any other cd deck (slight theft deterrant?).
1) I bought the cheapest cd player that has an external audio jack in the back of it.
2) The ashtray (or whatever went under that little lid in front of the shifter) was missing when I bought the car, but I would have removed whatever went in there anyways.
3) I then bought a universal iPod dock.
4) I made a bracket out of aluminum (cut from an old pc case I had lying around) I don't have a pic of it because its inside the center console and I really dont want to take everything apart to get to it.
5) I used double-sided tape to attatch the iPod dock to the bracket, then bolted the bracket w/ dock to the sides of the center console so the dock is accessible when that little lid is flipped up. This required a lot of modification to the underside of the center console because I wanted the iPod to be high enough to use its buttons. I also had to round of the back of the dock because it sits so close to the lid.
6) The cd player had an audio jack in the back, so i went from the audio output on the iPod dock to the audio input in the cd player.
You might notice that the ashtray lid has a line cut out of it. I had to do this because the lid doesnt just flip up, it rotates so that the back of it recedes back below the level of the center console. The cable going from the dock to the cd deck stuck out behind the dock, and didnt allow the lid to be flipped all the way back, so I made a hole in the lid where the audio cable is.
Overall, its very clean (no visible wires anywhere), its very low profile, and if I wanted to, I could hook the dock up to the cigarette lighter somehow and have it charge my iPod as well. It was a bit of work (especially when all I had were hand tools and a wimpy dremel), but I really like the outcome. Its great to be able to just flip a lid and plug in any iPod i want (my girlfriend always brings hers along cuz she hates all my music). You could even buy the universal dock that has the IR thing so you can use a remote to control the iPod, although you would have to have the IR reciever unconcealed which means it wouldnt be able to go in the center console.
Well, now I'm rambling so I hope this gives you some good ideas.
Attached Thumbnails iPOD integration??????Possible??????-100_3288.jpg   iPOD integration??????Possible??????-100_3291.jpg   iPOD integration??????Possible??????-100_3295.jpg
Old Mar 6, 2010 | 04:00 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Mark
Does anyone have the wiring diagram for the CDC port? I think this is as easy as adding the "play" button power out (Tape/play button) on 95 and newer decks and adding the right & left line in and ground.....
Pressing the play button would change input from radio or tape to Cd in this case line in or so I believe.
Old Mar 6, 2010 | 05:30 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Have I got the deck for you. Delco Pontiac CD player from early 4th gen with an IPOD jack built into the front of it.
http://cgi.ebay.com/GM-5EQ-CD-PLAYER...item2c530f13f8
Not my Ebay auction. I just stumbled on it awhile back.
Old Mar 6, 2010 | 06:16 PM
88 TA GTA's Avatar
No thanks, if I was going to spend $250 plus shipping, I would upgrade to an aftermarket deck with many more and newer features beyond line in, like MP3 disc compatibility and text Song name) & video display.
There is even cheaper versions on ebay only $138 with a better EQ 7 ban vs. 5 band.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_1959wt_1156
Just need the wiring diagram so I can create my own line in through the Aux CD input, I believe it is quite easy, someone must have the diagram....
Old Mar 8, 2010 | 12:18 AM
88 TA GTA's Avatar
in case anyone is looking for a Camaro radio with EQ, I found this for $39 and it has the aux line in - not CD thought.... but still a pretty good deal for those that prefer cassette.
http://cgi.ebay.com/ebaymotors/82-88...ht_4100wt_1156
Old Mar 24, 2010 | 11:43 AM
rjdavis2001's Avatar
Car: 91 Z28 Conv.
Transmission: 700r4 auto
Axle/Gears: 3.27 posi
hey, just to let you know I have a late model Monsoon, am/fm, cassette, with a EQ, and a AUX, built into the deck with 3 feet of cable to put the AUX line anywere you want, bought it 3 months ago its just and NOS unit that was modified for AUX, lights up in orange. Works Great, I just upgraded my deck, thats all, selling for 60.00 plus shipping of 20.00, total of 80.00, cheap for the radio, if interested PM me pics in interested
gta_knight
Sep 23, 2015 04:59 PM
Linson
Sep 21, 2015 01:08 PM
ULTM8Z
DIY PROM
Sep 16, 2015 09:15 AM
Linson
Aug 21, 2015 02:12 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
