WHATS LEFT!!!!!! Check it out!
Car: 1988 IROC
Transmission: TH-700r4
Feel free to make offers, I just want the rest of this gone.
double groove pully is 6 1/2 inches across
Timing light gun is brand new never used
Car: 1988 IROC
Re: WHATS LEFT!!!!!! Check it out!
stock pulley size
brand new never cut, SBC 305/350 crank scraper
Brand new never used rubber with metal impregnated valve cover gaskets.
Lightly used 3/8 inch screw in studs
Brand new comp cams 1.52 roller tip rocker. Was a race spare
(maybody somebody can use it?)
Just from the machine shop, OEM small block 400 rods. Shot peened and bead blasted, and came from a car with orginally only 20,000 miles on the motor. These have fresh Milodon connecting rod bolts.
Use these for your 383 or 400 build.
$75 shipped via USPS priorty 2-3 day flat rate box.
PM me for fastest response.
Car: 1988 IROC
Newer radiator with brand new pressure cap. No idea what its worth, so just offer me a price.
Brand new never used Chrome oil pan
Nearly brand new trans cooler. $34 shipped
Car: 1988 IROC
if you see something here you want pulled let me know.
TH700R-4 crossmember
Car: 1988 IROC
Brand new gas cap
TH700R-4 with overdrive shifter in great shape. NO SLOP.
Brand new Felpro intake gaskets. Only opened, never used.
Car: 1988 IROC
Starter bolts, grade 8 hex head crank bolt, valve covers, and shocks have been sold.
ALL THE OTHER ITEMS IN THE PICS ARE STILL FOR SALE
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
what are the sizes for the sway bars and could you give some info on the rear end?
Car: 1988 IROC
I will have to measure them tomorrow unless you can look them up. They are stock 1987 GTA front and rear sway bars.
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
how about the V8 brake line the one that goes across the K member. im doing a V8 swap in my V6 and i need to bend my line but while the motor is out i would prefer the V8 line anyway. let me know a price shipped to 33076.
Car: 1988 IROC
what is a fair price shipped? I'd have to ship it in a cardboard tube. Make me an offer and its yours.
Car: 91 Rs
Engine: 383 hydrolic roller carb
how much for the oil pan? Is this for an f body or just a reg sbc oil pan? what years. my buddy had a prob w/ a chrome oil pan that was put on his 383....the Y pipe didnt fit the and he had to get one custum made?
Car: 1988 IROC
Its for a regular SBC. Its the same dimmensions as a the stock pan so I dont know why it would not fit.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
How much for the timing light if I drive over and pick it up? Also interested in trans cooler but first the timing light.
Car: 1988 IROC
I'll check in the morning before I go to work for the part number on the intake gasket.
Spindles..sent PM.
Ed
Ed
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
how much for the water neck ?
Chromed or Polished ?
please let me know HERE or send me PM
Car: 1988 IROC
I'll take $13 shipped paypal or $12 money order. PM sent as well.
Car: 1988 IROC
Bump to the top. Deal feel through on the chrome water neck/thermostate housing.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 11, 2015 10:11 PM
