01 Z28 4thgen Plastic Gas Tank (w/sending unit)
Old Aug 18, 2008 | 04:24 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Complete plastic gas/fuel tank from an 01 Z28. 63k on it. Includes the sending unit(fuel pump, float, housing, etc) I dont have the fuel neck for it so you will have to find one somewhere else. $150 plus S/H.
Old Aug 20, 2008 | 01:04 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Re: 01 Z28 4thgen Plastic Gas Tank (w/sending unit)
bump: Will consider seperating sending unit and tank.
Old Aug 21, 2008 | 12:50 PM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
i am interested but am currently in the middle of swapping an lt1 into my 86 and havent decided whichn way i am going with the fuel delivery. do you happen know how easily it will fit into my thirdgen?.......also if the ls1 fuel pump is a proper fit to the lt1?
Last edited by fbirdroller; Aug 21, 2008 at 12:52 PM. Reason: forgot to ask sumthing
Old Aug 21, 2008 | 01:52 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
It will physically bolt in with no problems, you will have to pick up a fuel neck for it. The LS1 pump will work great in the Lt1.
Old Aug 21, 2008 | 06:36 PM
Engine: vortec 5.7
is it possible to put the neck from the stock tank on the plastic tank or maybe put a 4th gen neck on it from a v6 or sumthin?
Old Aug 21, 2008 | 07:51 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
You can modify the necks from the Ls1 cars to work with little effort. I'm not sure about using your stock neck. I had wondered that too, just cut off the stock neck and couple it to the tank with a section of rubber hose. It may be worth a shot.
Old Aug 21, 2008 | 07:55 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Axle/Gears: 9" Ford w/4.11's
I honestly dont know why RCI or someone cant make a fuel cell to bolt in shaped like a stock tank with a sump already installed.... I know there are a few out there, but I'm not dropping $3K on a tank.
anyways... bump for ya.
Old Aug 21, 2008 | 10:36 PM
karl's-92'-z28's Avatar
Car: Too many cars
Hey JT how much more shipped to 96701 Aiea,Hawaii
Thanks,
Karl
Old Aug 21, 2008 | 10:57 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
FedEx is $165.00
USPS is $124.00 Parcel post but they may not ship it due to it being a gas tank. It is comepletely empty and has aired out for several months so I'm not sure on this. I know FedEx will ship cause thats how I recieved it.
Old Aug 21, 2008 | 11:04 PM
Car: Too many cars
$215 shipped thanx JT, I'll pass for now, thanx for checking though.
Karl
Old Aug 21, 2008 | 11:16 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
TTT I can ship this in the Continental US for under $50 depending on your location. In most cases it would be less.
Old Aug 22, 2008 | 06:25 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Refresh my memory. How does the EVAP system work on those cars? Its all handled at the tank. Correct? Does it need any input from the ECM to work correctly?
Old Aug 22, 2008 | 11:09 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Tank Has been Sold. Thanks, Jt
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
