Gas Tank Woes
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Gas Tank Woes
Well my new Spectra Premium Fuel tank( 500 miles on it), is now dripping gas into a drain pan as I type. It is the ONLY replacement tank on the market and is a POS. Slightly oversized and neck is flimsy. Was a PITA to fit and due to the flimsy neck issue, is leaking at the junction of the neck and tank(cracked). Sooo, does anyone have a good OEM tank for sale? It must be clean and rust free or at least can be cleaned to spec. Since I have to drop the rearend, exhaust (you guys know), I want to put a tank back in that fits and has a fixed sturdy neck like the original. If not I'm open to suggestions. I'm also PO'ed! Was going to Woodlands meet tonight and Chick-Filet tomorrow. So instead I'll drink to abandon and tomorrow, start tearing apart my car. Again.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Gas Tank Woes
http://houston.craigslist.org/pts/797664925.html contact that guy, i met him at the chick fillet meet, seems like a good guy, he parted a bunch of cars, i bet he has a tank for you
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Gas Tank Woes
Can't you order the baffled 1LE tank from GM?
http://www.trademotion.com/partlocat...?siteid=214632
Look for a tank from a 1990-92 Camaro. The baffled gas tanks go by two different part numbers.
10121026
10269091
The 1st number seems to have been deleted from computer databases. But the 2nd one still exists. If that's the tank you order, it should be the 1LE baffled fuel tank (the only one that GM still makes for 3rd gens).
10121026
10269091
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: Gas Tank Woes
I tried your link (good resource BTW) , they say they will send you one but it is almost $400.00 with shipping.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Re: Gas Tank Woes
And it's a Spectra Preminum tank with the Goodmark black coating. A POS in sheep's clothing.
Car: 1989 GTA
Re: Gas Tank Woes
Sam Taylor Buick/Pontiac
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: parts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Try them with the parts numbers I put up earlier.
Bohemian
Aug 15, 2017 05:11 PM
