Lot of performance and stock parts
Old Dec 15, 2008 | 04:14 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
*HEAVY ITEMS ARE PICKUP ONLY*
Pair of 083 heads rebuilt not too long ago - 100
Stock tpi runners (a couple tiny dents) - 25
Ported tpi plenum (egr walls gone, tb opening enlarged, siamesed ports) - 50
Ported stock tpi lower base (opened up throughout the entire ports) - 50
K&N speed density tpi tb mounted filter (brand new) - 20
Dynomax 2.5" inlet dual 2.5" outlet muffler (5k miles no rust) - 20
4th gen stainless steel muffler 3" inlet dual 2.5" outlets (50 miles) - 30
91-92 speed density tpi wiring harness for camaro (full harness no cuts) - 50
Comp cams XE-268H camshaft (NIB) - 75
Comp cams 7949-16 set of 16 1 piece chromoly 5/16 7.300" pushrods(NIB) - 80
Manley 1.250" diameter valve springs with matching Manley +0.050" clearance retainers(good for more lift with no head work)(2k miles) - 125
Vortech 30Ib fuel injectors(set of 8, great condition, new o rings, i just needed larger ones, black with a red ring on top) - 125
TBI ECM with stock memcal for an 89 firebird with VATS - 25
TPI factory fuel rails(no dents in tubes) - 25
TPI firebird fuel lines crossover from rubber-rails(no rust painted to keep it away) - 15
TPI firebird factory air intake canister modded for more airflow - 20
TPI firebird factory air intake rubber piece off of the canister to MAF sensor - 15
TPI firebird factory air intake rubber piece from MAF to TB (modded for nitrous nozzles) - 15
Old Dec 15, 2008 | 08:49 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Axle/Gears: 10 Bolt 3.08 Posi
Re: Lot of performance and stock parts
Could you post or send pics of the last 3 items to gaccett@yahoo.com
Old Dec 16, 2008 | 12:14 AM
fbodyman's Avatar
I sent you a PM.
Thanks!
Old Dec 16, 2008 | 03:40 AM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
do you have a TPI ECM to go with that harness?
Old Dec 16, 2008 | 03:42 PM
Engine: LO3
pictures as requested by all. Gaccett just a note remember the elbow that goes on the tb has 2 holes near the throttle body one underneath and one driverside on top but they can be plugged if you need. I however at this time dont have a picture of the rubber piece from MAF to canister at this time but i garauntee mint condition and can get pictures at work if youd like tomorrow. Luke no i do not have the computer im keeping it sorry. The picture of the ported base was before it was ported even more the second time if you wish i can go down to work tomorrow and take more pictures of it from all sides. It is now ported to fit a 1205 intake manifold gasket on that side and ported as large as i felt comfortable with on the runner side. Also the plenum picture shows the porting in progress not the egr walls are smooth and dont intrude into the throttle bore area anymore and the sides are even ported down a little smoother.
Old Dec 16, 2008 | 03:44 PM
Engine: LO3
Last edited by vipershark11; Dec 16, 2008 at 03:49 PM. Reason: Automerged Doublepost
Old Dec 16, 2008 | 04:14 PM
cam91rs1's Avatar
Suspended
Car: 91rs camaro conv
Engine: 305 tbi
Transmission: 700r4 w/shift kit
pm'd you i think i can help u out lol
Old Dec 17, 2008 | 11:54 AM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
I actually needed the intake duct to be straight not angled. Sorry.
Old Dec 17, 2008 | 01:09 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
pics of harness??? im very interested
Old Dec 17, 2008 | 06:20 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Still have the fuel rail assembly? camaro87-alex may need it. PM him for the sale.
Old Dec 17, 2008 | 06:27 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
what size valves are in those heads? and what cc is the chambers?
Old Dec 17, 2008 | 08:51 PM
Engine: LO3
harness sale is SOLD
ported plenum and base is SOLD
fuel rail is still available i will pm him. thankyou
the 083's have 64cc chambers with 1.94/1.50 valves.
Old Dec 18, 2008 | 12:58 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Where in CT are you?
Old Dec 18, 2008 | 03:25 PM
Engine: LO3
im 10 minutes from hartford.
Old Dec 19, 2008 | 02:50 PM
Engine: LO3
items updated on whats sold.
also for sale a black Marshal nitrous pressure gauge(mechanical 1/8npt port)
Old Dec 21, 2008 | 01:15 PM
Engine: LO3
bump for a boring snowy day
Old Dec 21, 2008 | 03:58 PM
bonesbrakr's Avatar
Wondering if the K&N filter will fit a holley 58 mm TB as the one i had on the stock TB is too small and am forced to now use the stock intake tubing....
Old Jan 3, 2009 | 09:00 PM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
pm sent
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
1nastygta
Aug 8, 2015 07:38 PM
