Need Lower TPI Intake Manifold
Old Jan 14, 2009 | 09:46 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am in need of a TPI intake manifold. I only need the base and not the runners, fuel rail, or plenum. I broke one of the thermostat housing bolts off on mine and someone got drill happy and ruined the manifold .
Any finish is fine, just needs to have all bolt hols intact. I am in northeast Ohio (44057). Thanks
Old Jan 14, 2009 | 04:17 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: Need Lower TPI Intake Manifold
What year?
Old Jan 14, 2009 | 05:11 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Your existing intake has the Cold Start Injector yes? I have a spare intake for my TPI L98 and I'm pretty sure they are the same intake but not 100%, do you know anything about this?
Yes they are the exact same parts. PM me if your interested.
Old Jan 14, 2009 | 10:22 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Originally Posted by tpi-hearse
What year?
It is an 87 motor with 9th (cold start) injector. I believe the actual intake base is the same throughout all the years.
Old Jan 14, 2009 | 10:30 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
I had the same problem with mine as well
You are not alone
I had mine fixed !
A machinist removed the broken bolt
filled the "cavity" and smoothed out the top
and helicoiled the new hole, using the housing as a template
IT works great
Old Jan 14, 2009 | 10:38 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
You are not alone
I had mine fixed !
IT works great
I considered having it fixed, but after I messed up the hole, I decided to just get a new one. I think it is also probably cheaper to get another one these days than to have a machinist fix my old one. I like to take the easy way when it doesn't sacrifice quality or cost more
Old Jan 14, 2009 | 11:28 PM
88 IrocZ Vert's Avatar
have one asking 65 shipped.
Old Jan 18, 2009 | 03:52 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I have one from an 87 iroc...It was the same way..but I had it fixed with a heli coil.. Works great... I will let it go for $20 plus shipping... It has been painted in cast iron grey paint... Looks good.. let me know..
Old Jan 20, 2009 | 09:15 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Thanks for all the replies. I have one on the way
1992rs/ss
Jan 31, 2025 05:10 PM
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
