Heater control for 84 trans needed
I am looking for a working/good condition heater control unit (the part that controls the blower and ac motors). Needs to be from the older model thirdgen 82-84 years. If available please post pics of all sides, most importantly the back side where the connection points go...since I need to ensure it will work on my 88 gta without major rewiring. Thanks!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Heater control for 84 trans needed
I'll try to get some pictures for you later tonight..........
What is your ZIP code ???
All I've found in the early Firebird style is an AC delete heater control. I havn't found a 82-84 Air conditioning / heater control yet.
IIRC all 82-92 AIR CONDITIONING controls are interchangeable. I think they are only different in style and possibly back-lighting color. I have several 85+ AC/Heater controls.
I'm going to be looking up a lot of stuff tomorrow and will re-post if I find the correct 82-84 AC/Heater control that you requested.
Thanks John. I appreciate the research. I actually went to a local junkyard that had an older 82-84 model AC/heater control. The thing was completely rusted through, so I couldn't get it. But I DID notice that back connections were definitely different from what I currently have for the 88. So yeah - if you do find anything, I'd be happy to purchase it pending a closeup review of the pics you provide. Thanks again man!
So are you still looking for the 82-84 style or do you want the one with the right connections.If you want the 82-84 style i have a couple of them.Also have one from a 87 trans am i think.Pm me and let me know if you still need one.
Black - I am still looking for an 82-84 style control. But see my other post. I'm not sure my current car's wiring will allow me use those style controllers (unless you have a suggestion).
https://www.thirdgen.org/forums/elec...converted.html
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i have an 82 bird with a/c control panel i might sell..
let me know...
good luck
let me know...
good luck
Thanks Randy. But from what I'm understanding, I won't be able to convert the wiring since I'm coming from a Digital Control box (the one that has push buttons). As you can see in the photos, it's a lot different in the back which means a BIG headache trying to rewire for your style. As much as I would LOVE to buy it from you, I don't think it's possible (UNLESS ANYONE HAS A GOOD SUGGESTION!!). Thanks anyway.
Engine: 4.3L Z TBI
ok thats cool but if anyone else is needin 82 83 48 HVAC control panel then lemme know!
you gotta email me, or text me 217 671 7792 i dont normally check forums except maybe once in a few months
good luck!
good luck!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
The_Phoenix
Feb 4, 2016 07:10 AM
