Comp cams camshaft and springs
Car: 1990 Iroc-Z Vert
Engine: TPI 350
Axle/Gears: Drum with 2.73 posi
This is a Compcams camshaft part# 08-501-8 that I had in my 1990 Camaro TPI 350. I had this camshaft in my camaro for about 15k. I pulled it out cause I was selling the car and I put everything back to stock. The spring set is brand new, I never put the springs on the engine. Springs set part# 986-16. This is the spring set that Compcams reccommends for this camshaft. I paid around $400 for the cam and spring set.
Asking $200 OBO
PM me if your interested.
Cam specs
Basic Operating RPM Range: 1,200-5,200 RPM
Duration at .050" lift: 212 int./218 exh.
Valve lift with 1.5 ratio: 0.488 int./0.495 exh. lift
Best in tuned port injection engines.
Spring specs:
Comp Cams #249-986-16
Dual Valve Springs
Outer inside diameter: 1.070"
Inner inside diameter: .697"
Seat load: 132lbs @1.750''
Open load: 293lbs @1.250''
Coil bind: 1.150''
Rate: 322lbs/in
With damper
16 per package
Asking $200 OBO
Cam specs
Spring specs:
Dual Valve Springs
Coil bind: 1.150''
Rate: 322lbs/in
With damper
16 per package
Engine: TPI 350
Engine: TPI 350
Re: Comp cams camshaft and springs
Car: Hot Wheels
Engine: Stroker 383
woould you consider125 + ship to 80915 for cam or 175 shipped for both .Im a little unsure about springs only due to not knowing max allowable cam lift before bind #330 usaully around .550-.600 lift. strange they dont show max cam-lift spec.
Car: 87 GTA
Axle/Gears: 3.42 posi
Jus curious if you liked the cam? This is the one comp cams told me to get, sucks i misssed out.
Engine: TPI 350
Yes I liked this cam a lot. Gave it a nice little rumble at idle but not too bad. Helped a lot with power on the top end too which was a problem with the TPI engines. The only thing I didn't do which would of helped a lot was large tube runners and a large mouth intake. Cause the standard intake restricts the flow a lot in the higher RPM's.
ambainb
Apr 25, 2016 09:21 PM
blackroc68
Sep 1, 2015 08:01 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
