FS: Performance Intake & Throttle Body
Old Jul 2, 2012 | 09:01 AM
ralph85's Avatar
Want a title? Post!
Selling both the intake (#1 below) and the TB (#2 below) for $600 combined plus shipping or separately for the prices shown below. The combination below will fit under a stock C4 Corvette hood with dropped base air filter or a Procharger standard profile carb hat which can be connected to the MAF or directly to the front mounted air filter. I assume it would have no problem fitting under an F-Body hood. Please PM me if interested. Thanks.
1. Edelbrock Victor E intake with Fuel rails. The intake has been ported to match a 1206 intake gasket and the plenum area has been worked to match the throttle body. I installed the intake new in February as a test for about 2 months. Intake and rails sell for over $420 in Summit. Selling for $325 plus shipping
http://www.summitracing.com/parts/EDL-29785/
http://www.summitracing.com/parts/EDL-3630/
2. Accel 1350 CFM carb style billet throttle body with IAC, TPS & throttle bracket. Very little use and in excellent condition. The throttle body sells for over $550 in Summit and the C4 style IAC adapter harness & Throttle bracket sell for an additional $25. Selling all for $325 plus shipping.
http://www.summitracing.com/parts/ACC-74202S3/
Old Jul 9, 2012 | 09:39 AM
ralph85's Avatar
Want a title? Post!
Re: FS: Performance Intake & Throttle Body
ttt
Old Jul 10, 2012 | 09:45 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Why are you removing it? What setup was it planned for? Where are you located?
Old Jul 11, 2012 | 08:58 AM
ralph85's Avatar
Want a title? Post!
I removed it because the super victor & custom made plenum seemed to work slightly better on my application. There is very limited space under a C4 Corvette hood. The front mounted air filter, carb hat and required duct work was a little restrictive in the upper rpms. I think it would have worked better if i could have brought cool air directly into the throttle body. My application is a C4 corvette with a 406 & brodix M2 T1 heads used primarily for drag racing. BTW, the performance difference was minor (less than a tenth) and the Victor E setup drove better on the street. In fact, I'll sell either setup and keep the other........I just don't need both ;o)
I'm in New York and usually race at Etown.
Old Jul 25, 2012 | 08:47 PM
ralph85's Avatar
Want a title? Post!
TTT
Old Jul 25, 2012 | 09:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Bump for an Awesome price! I already have the single plane Accell with the 1200 cfm TB otherwise I would take it. Great intake, so much better and cheaper than trying to make performance TPI.
Old Sep 23, 2012 | 06:11 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Is this still available?
Old Sep 24, 2012 | 02:45 PM
ralph85's Avatar
Want a title? Post!
Yes.......still have both the intake and TB.
Old Dec 28, 2012 | 10:13 PM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
You ever sell?
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
