Parting out 89 camaro
Old Sep 1, 2012 | 08:02 AM
nealey101585's Avatar
Car: 1989 RS
Engine: 350 HO
Transmission: 700r4 pheonix trans rated 500hp
I am parting out a my 1989 Camaro rs has no engine tranny or drive shaft. However rest of car is solid, has original dash pad with 1 small crack in the speaker area on the left side. All the steering components have about 100 miles on them. Any questions feel free to ask. Also if you would like some pictures just ask and you shall receive.
Old Sep 1, 2012 | 11:38 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Parting out 89 camaro
Radiator?
Old Sep 2, 2012 | 09:10 AM
Car: 1989 RS
Engine: 350 HO
yeah I still have the radiator one of the holes is plugged though belive it went to the heater???? Not sure I can't remember it was on the right side near the top.
Old Sep 2, 2012 | 09:21 AM
Engine: L31 350
What's it plugged with
Old Sep 2, 2012 | 12:04 PM
Car: 1989 RS
Engine: 350 HO
I screwed in a bolt and put some epoxy over it to hold it from leaking.
Old Sep 2, 2012 | 01:08 PM
Engine: L31 350
Pictures and price shipped to 46036. Not sure if I'll take it yet, that bolt scares me
Old Sep 2, 2012 | 02:21 PM
Car: 1989 RS
Engine: 350 HO
Size:  6.1 KBName:  GetAttachmentaspx5.jpg
Size:  5.4 KBName:  GetAttachmentaspx4.jpg
$30.00 shipped.
Old Sep 2, 2012 | 04:43 PM
Engine: L31 350
What's with the rubber hose? And is the bolt removable?
Old Sep 2, 2012 | 06:01 PM
Car: 1989 RS
Engine: 350 HO
I used a rubber hose because it was easier to route the tranny line with my setup it will still work with the steal line. the other hoses I just cut to pull it out real quick and get pictures for you. And I already removed the bolt for you. It was the top picture. You can use it as is or you can trim the excess epoxy off of it. The top left inlet for engine is chipped but there is still more than enough plastic to slide a hose on.
Old Sep 2, 2012 | 09:01 PM
Engine: L31 350
Okay I'll take it! Can you hold it till next weekend for me?
Old Sep 2, 2012 | 09:02 PM
Engine: L31 350
And it is a v8 radiator right?
Old Sep 2, 2012 | 09:50 PM
Engine: L31 350
gauge cluster still in the car? and if so what kind is it and price?
Old Sep 3, 2012 | 07:31 AM
Car: 1989 RS
Engine: 350 HO
cluster is gone.
Old Sep 3, 2012 | 07:48 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
disc or drum brake rear?
Old Sep 3, 2012 | 07:50 AM
Car: 1989 RS
Engine: 350 HO
drum 2:73
Old Sep 3, 2012 | 11:45 AM
mstacy1's Avatar
Does it have a 21mm rear sway bar?
Old Sep 3, 2012 | 02:34 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Rust free t-top bar shipped to 26757?
Old Sep 3, 2012 | 03:12 PM
Car: 1989 RS
Engine: 350 HO
it is not rust free. has a lot of rust on driver side
Caspar
Jun 19, 2016 11:19 PM
InfinityShade
Aug 22, 2015 08:00 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
