GM Steering Shaft Upgrade
Old Dec 1, 2012 | 10:15 AM
MC87SS's Avatar
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
I have a new product for you die-hard GM fans that refuse to put a Chrysler part on your car. I have done some research and testing and now have available a GM steering shaft upgrade. In addition to being a GM part they also have a set screw you tighten after installation to eliminate all shaft movement, they have a metal bushing instead of the worn out mostly broken plastic bushing on the inner shaft and for those of you with large tube headers the shaft is the opposite of the Jeep shaft so the small end attaches to the steering column allowing the most available clearance.
This is the end that attaches to the steering column:
This is the steering box end, note how nice the u-joint is:
Set screw in the center:
Metal bushing in lieu of plastic:
As with everything i sell these will be prepped, painted, greased and ready to install.
These GM units will be $70 shipped to the lower 48.
I only have 2 of these in stock so hurry.
PM me if your interested, please title it GM Shaft.
Old Dec 1, 2012 | 10:25 AM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Re: GM Steering Shaft Upgrade
PM Sent
Old Dec 1, 2012 | 10:28 AM
MC87SS's Avatar
Engine: 305/350/454
1 Left.
Old Dec 1, 2012 | 11:25 AM
daniel92345z28's Avatar
Car: 82 camaro z28
Engine: gen 6 454 carburated and cammed
Transmission: ls1 t56 trans
Axle/Gears: currie f9 with 3.70 gears
if its a direct bolt on to a 82 camaro z28 i will take it,
pm me your paypal info
Old Dec 1, 2012 | 01:12 PM
MC87SS's Avatar
Engine: 305/350/454
Yes it is a direct bolt in.
See my Jeep steering shaft thread.
Old Dec 1, 2012 | 03:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Looks like the modified Astro van shaft I have in my car.
JamesC
Old Dec 1, 2012 | 06:25 PM
MC87SS's Avatar
Engine: 305/350/454
JamesC
Exactly James.
Old Dec 2, 2012 | 05:28 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Minor point, but I think the steering shaft is a Saginaw part, rather than being specific to any brand of car.
Old Dec 2, 2012 | 06:46 AM
MC87SS's Avatar
Engine: 305/350/454
Due to lack of response by daniel92345z28 i assume he backed out.
Still have one available.
PM me if you want it..
Old Dec 2, 2012 | 12:47 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
PM sent.
Old Dec 2, 2012 | 06:39 PM
JamesC's Avatar
MC,
Have you considered throwing in the Astro bearing as part of your package?
JamesC
Old Dec 3, 2012 | 07:54 AM
MC87SS's Avatar
Engine: 305/350/454
MC,
JamesC
James,
I no longer have my 3rd Gen so the whole Astro bearing & shaft was new to me. Now i have done some more research i will check into it. I need to see how hard the bearing is to pull and what tools i need. If it doesn't add too much time i may start doing that. I found a place that has 25 jeeps and 15 astro vans so i may be making a trip but its 2 1/2 hours each way from my house.
Old Dec 3, 2012 | 06:05 PM
JamesC's Avatar
A clip, a cap, and the bushing. Perhaps three minutes. Check the following:
https://www.thirdgen.org/forums/susp...g-bearing.html
JamesC
Old Dec 3, 2012 | 07:07 PM
MC87SS's Avatar
Engine: 305/350/454
I will check into them, what kind of clip is it? Do i need snap ring pliers to remove it?
Old Dec 3, 2012 | 08:36 PM
JamesC's Avatar
Check the first pic in post #7 of the above for a picture of the clip. Screw driver/prying instrument will do it.
JamesC
Old Dec 4, 2012 | 12:50 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Still available?
Can paypal asap, thanks.
Old Dec 4, 2012 | 12:57 PM
Stangski09's Avatar
Still available?
Old Dec 4, 2012 | 04:48 PM
MC87SS's Avatar
Engine: 305/350/454
Originally Posted by Stangski09
Still available?
Sorry both are sold.
I hope to be getting more in 2 weeks.
I do have a 1 Jeep shaft ready to ship if you would like that.
If you want to get on the waiting list for a GM shaft please send me a PM titled GM Steering Shaft. This helps me keep track on a first come first serve basis.
Old Dec 19, 2012 | 04:15 PM
Dueling73s's Avatar
Pics on my car
Old Dec 27, 2012 | 05:01 PM
MC87SS's Avatar
Engine: 305/350/454
Awesome, glad it worked.
I have another batch on the way.
PM me to get on the list.
Old Dec 27, 2012 | 10:17 PM
the blur's Avatar
No rag joint ?
Old Dec 27, 2012 | 11:29 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Originally Posted by the blur
No rag joint ?
No. Not needed.
Old Dec 28, 2012 | 06:43 AM
the blur's Avatar
If you take out the rag joint, doesn't that promote all the road virbration, and road jitter up to the steering wheel ??
Old Dec 28, 2012 | 07:19 AM
JamesC's Avatar
For me, steering box noise seems to be amplified. That said, many upgrades are trade-offs on our cars--poly vs. rubber, for example.
JamesC
Old Dec 28, 2012 | 08:03 AM
MC87SS's Avatar
Engine: 305/350/454
I will have a few of these available with a rubber isolator if anyone would prefer that.
Pics of both types this weekend.
Old Dec 28, 2012 | 08:45 AM
TTOP350's Avatar
We aren't building caddys, please hand over your man card
Old Dec 28, 2012 | 07:31 PM
MC87SS's Avatar
Engine: 305/350/454
Here is the type with the rubber isolator.
These are so much nicer then the Jeep Shafts in my opinion.
Please specify if you want one of this type, i can get them if there is a desire for them.
Old Dec 29, 2012 | 12:16 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Please don't forget that I am on your list, Thanks
Old Dec 29, 2012 | 12:49 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Ill take one with the rubber isloator if your willing to ship to canada? Let me know as its a done deal if you are. Thanks
Old Dec 29, 2012 | 01:01 PM
MC87SS's Avatar
Engine: 305/350/454
I have another batch on the way and i am also going to a yard Monday and may get some more while i am there.
I didn't plan on getting any with the rubber but if you want that kind please let me know ASAP and i will get some.
I am working my way thru the list. PM Sent!
Originally Posted by 6SIX6
Ill take one with the rubber isolator if your willing to ship to Canada? Let me know as its a done deal if you are. Thanks
Shipping to Canada adds $30 to the shipping cost.
The one i have with the rubber is on hold for someone but if they back out its your.
Please PM me if interested, its the only way i can keep everyone in order.
Label the PM GM Steering Shaft and let me know you want the rubber kind.
Thanks.
Old Dec 30, 2012 | 10:07 AM
MC87SS's Avatar
Engine: 305/350/454
Originally Posted by ccc
70 $ shipped is a steal though. i have been doing the u joint thing for over 10 yrs
Thanks for the kudos, i try to make it easy on everyone with a flat shipped price.
Others that sell play the lower price then add shipping game. and sometimes even try to make money on the shipping cost.
I clean them up, remove the column end, re-clock it 90 degrees, press it back on and tack weld it just to make sure its not going anywhere. Then i clean the bolt threads, spread the ends & test fit on a steering column, sand & paint them gloss black. Before shipping i grease the inside of the shaft, wrap both pieces in foam and stretch wrap for shipping.
Sold out this batch already but have more on the way.
PM me to get on the list as i should have some ready to ship next weekend.
GM Shafts $70 Shipped
Jeep Shafts $60 Shipped
Old Jan 1, 2013 | 07:05 AM
MC87SS's Avatar
Engine: 305/350/454
I have more of the Solid GM shafts available.
I also have the Astro bearings available for an additional $10 with the purchase of a shaft.
PM me if you want one.
Old Jan 1, 2013 | 07:59 AM
Dueling73s's Avatar
PM Sent
Old Jan 3, 2013 | 07:22 AM
MC87SS's Avatar
Engine: 305/350/454
I have 2 GM shafts left ready to ship.
By Monday i will have another 8 GM shafts, 5 Astro bearings & 7 Jeep Shafts ready to ship.
Old Jan 4, 2013 | 05:44 PM
MC87SS's Avatar
Engine: 305/350/454
Prepped & Primed, paint tomorrow & ready to ship Monday.
Old Jan 4, 2013 | 06:23 PM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
Awsome, I like your style, you've got quite the assembly line going on there!
Old Jan 4, 2013 | 06:58 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Received mine today, But not sure about rubber bushing, where does it go. Also like your sign about towing and selling for junk. Very nice looking part, will be pulling my engine soon and will give you good pics of install in a few weeks.
Old Jan 5, 2013 | 09:43 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
I pm'd you to be on the list for the jeep shaft, but I 'll take one of these instead if you still have some!
Old Jan 5, 2013 | 02:26 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Got mine today and its a nice looking part. Planning on installing it tomorrow. Thanks MC87SS!
Old Jan 5, 2013 | 07:38 PM
MC87SS's Avatar
Engine: 305/350/454
I assume your talking about the bearing, it goes in the end of your steering column to replace the plastic one that came from the factory.
Glad your happy with it.
Please remember to post some pictures.
We all love pictures.
Old Jan 6, 2013 | 01:03 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Got it swapped in this afternoon. Hardest part was wrestling the stock shaft out between the brake hard lines. I ended up buzzing part of the plastic cover off the stock one with my dremel to give me some more room.
I also had to grind a small amount of material off of the top of the column end to give the new bolt some room where it passes through the collar. I snapped a few crappy pics with my phone.
I probably won't be driving the car for another few months since there is salt on the roads. Looking forward to getting it back on the road in the spring.
Attached Thumbnails GM Steering Shaft Upgrade-grinding.jpg   GM Steering Shaft Upgrade-bolt_view.jpg   GM Steering Shaft Upgrade-view2.jpg
Old Jan 6, 2013 | 05:18 PM
MC87SS's Avatar
Engine: 305/350/454
Awesome, thanks for the pics.
I guess I should post the installation instructions from the Jeep shaft in this thread.
All orders have been shipped.
Still have a few shafts & 2
Bearings left.
Old Jan 7, 2013 | 12:12 PM
MC87SS's Avatar
Engine: 305/350/454
These are the instructions from my Jeep Shaft thread, figured i would post it here also.
I have had many questions about the notching of the shaft so i thought some more instruction may be in order.
The notch required for the bolt has to be made on your steering column shaft NOT the Jeep Shaft.
To make things easier i used an extra steering column for the pictures. The area you are seeing is the part of the steering column that comes thru the firewall.
This is what it looks like once you remove your stock shaft.
Slide the Jeep shaft on as shown.
If you look thru the bolt hole you can see where the column shaft sticks out into the opening.
Mark the center of the bolt hole with a marker.
I got carried away with my die grinder so the notch is larger then it needs to be.
Now you can see the bolt hole is clear straight thru.
Bolt installed and shaft locked in from sliding off.
Hopefully this helps.
Old Jan 8, 2013 | 11:40 AM
MC87SS's Avatar
Engine: 305/350/454
Have a couple GM Shafts left and 4 Jeep Shafts.
Old Jan 8, 2013 | 11:45 AM
Car: 1971 Camaro
Engine: 427
Whats the deal with the astro bearing? What does it replace?
Old Jan 8, 2013 | 12:05 PM
JamesC's Avatar
The bearing replaces the OE bushing.
JamesC
Old Jan 8, 2013 | 01:47 PM
MC87SS's Avatar
Engine: 305/350/454
Thanks James.
Sorry Johnny i already shipped your shaft so it would cost extra to send you the bearing if you wanted one.
Old Jan 8, 2013 | 01:48 PM
Car: 1971 Camaro
Engine: 427
Thanks James.
Thats ok.
Old Jan 9, 2013 | 09:03 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Can you make a gm shaft with rubber isolator and bearing? And will it be a simple install ...could not align my car properly because the slp headers rub on the header and dont want to "massage" the header
Old Jan 10, 2013 | 04:11 PM
Car: 1971 Camaro
Engine: 427
Got mine today! Great part, great prep, great packing!
