What is the pros and cons of mechanical pumps?
Old 03-27-2007, 03:31 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I really cannot stand the mallory regulator and tpi fuel pump. I want to go mechanical. So, what is the pros and cons of a mechanical setup?
The mallory keeps pressure erradic and sounds like I have a bad alternator.
I have a feeling some people will say do neither and get an inline electric carb pump.
Anyways question stands.
Old 03-27-2007, 04:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: What is the pros and cons of mechanical pumps?
Mechanical pumps are reliable, don't draw electrical power, SUPER easy to replace, cheap, and are actually meant to work with a carb. No hassles, no fuss no muss.
Drop the tank and toss the pump, then set it up right with a "normal" carb pick up. Then remove the filter that's under the drivers seat, and put in a little carb filter after the mech pump, and bolt on the mech pump. Use a return style pump, the normal stock Carter 6626 or whatever it is should work great.
Old 03-27-2007, 05:49 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
buy a good mechanical pump. 110gph for anything with any power. I had a store bought cheapie and with the foot to the floor my guage i setup on the windshield went to 1psi. The car never skipped a beat either, but i suspect if i had kept it floored for a while it could run lean. I currently have the summit 110gph pump. I would reccomend it.
Old 07-06-2007, 04:07 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Does anyone have some pictures of the clearance they have between their pump and the triangular brace that attaches from the front fame rail to the K member? I have a mechanical pump but the lines are going to interfere with that brace and I was wondering if it was just a problem with the pump I have or if people had modified their braces.
Old 07-06-2007, 04:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which pump do you have?
Old 07-06-2007, 05:07 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
I'm not really sure what it is. It has no name on it at all, it looks like a Summit pump but it has no markings on it anywhere that I've seen.
This looks like it may be the one I have but I'm not sure.
Old 07-06-2007, 05:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There shouldn't be any clearance problems with that pump.
Old 07-06-2007, 05:48 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
I'm going to have to fiddle around with it I guess. If it is that summit pump it states that the thing rotates but I suppose I'd have to loosen some screws up to actually move it As it is set up now the fuel lines will not clear that triangular brace.
Old 07-06-2007, 05:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
To reorient the fittings you have to unbolt the bottom and reclock it.
Old 07-06-2007, 06:17 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Yeah thats what it looks like. I was afraid if I just tore it apart that a thousand tiny parts would fall out I'd be buying another one
I attached a pic of the dillemma:
Attached Thumbnails What is the pros and cons of mechanical pumps?-fuel-pump.jpg
Old 07-06-2007, 06:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll be surprised by how few parts there actually are to a mechanical pump. There's nothing to fall outwhen you remove the screws holding the top on.
An orientation more like this should work for you.
Old 07-06-2007, 06:33 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Indeed. Thanks for the info. I found numbers on the pump it turns out it is a Holley 12-327-11.
theshackle
03-05-2017 06:37 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
fbirdroller
09-02-2015 10:27 PM
Dialed_In
08-20-2015 01:45 PM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: What is the pros and cons of mechanical pumps?
