Carb opinions?
Old 01-27-2008, 07:37 PM
UrbanGTA's Avatar
Car: 84 Z28
Engine: 355
Carb opinions?
Hey guys, got another annoying "what carb should I use" question. Specs are in sig.
Approx 400hp on the engine, this is mostly a street car, summer use only.
Thanks for any advice you guys have, i'm a diesel mechanic but I don't know jack **** about carbs
Old 01-27-2008, 08:05 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Carb opinions?
that 750 a vacuum secondary or double pumper?
hows it run now?
Old 01-27-2008, 08:19 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Carb opinions?
Greetings, fellow diesel tech!
Now is the time! If you are smart enough to work on diesel engines and understand how their fuel systems work, then you are smart enough to do computer tuning with your laptop.
My vote is a computer quadrajet with an EST HEI distributor. Let your engine computer run the fine tuning after you make it right and lock up your converter at the appropriate times. You'll have the best of everything with power and mileage.
There are some pretty stout 383's running the same specs as you around here with the CC Quadrajet. I think 57kid is running that...
Search up that. It'll be a few hundred bucks but you'll be really happy!
Old 01-27-2008, 09:34 PM
UrbanGTA's Avatar
Car: 84 Z28
Engine: 355
Re: Carb opinions?
I should elaborate, the 750 on the car is vacuum secondaries and it's junk, throttle shaft has massive play (vacuum leak) and the carb is real old. Time for a new carb, i'm also looking not to spend much cash as i have a diesel hot rod also which I would prefer to invest my money into. But i don't want to play with rebuilding this carb so thats not an option. I just want to get this camaro running nicely again. I was think a holley 670 street avenger might be good for my application.
Old 01-29-2008, 06:24 PM
UrbanGTA's Avatar
Car: 84 Z28
Engine: 355
Re: Carb opinions?
Bump
Old 01-29-2008, 07:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Carb opinions?
best choice is a 750 double pumper holley, 750 proform, quick fuel etc, with mechanical secondaries.
Old 01-29-2008, 08:54 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
350, actually. Somewhere around 360 HP.
If you don't have a CC carb, it's hard to justify installing one. But, if donor equipment is available, maybe.
Old 02-16-2008, 07:05 PM
Hotrodrobert's Avatar
Re: Carb opinions?
Quadrajets are the best street carbs ever made!! If you have a computer now, set up the carb and have a chip made. If not, just get the Q-Jet and you will have the best mileage and least trouble of any carb!!!
If you need help tuning, get the Cliff Ruggles book.
Old 02-17-2008, 02:12 AM
ekoller's Avatar
Re: Carb opinions?
I have a 400hp 440tq motor with a 700r4 and use a speed demon 650ve, after the dyno tune it proved it was better than getting the 750 which lost torque off the bottom end. If you plan on running over 6500rpms then go with the 750.
Old 02-19-2008, 10:52 AM
Re: Carb opinions?
If you can find someone to tune it, the Q-Jet will run with ANY carb up to rated flow. Just ask the superstock drag racers!!!!!
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Jerzyperson
Carburetors
11-13-2015 01:07 AM
budowski
Carburetors
10-02-2015 10:16 AM
Jlanz55
09-08-2015 11:28 PM
Wylecoyote08
09-08-2015 08:26 AM
Quick Reply: Carb opinions?
