carb sticking?
Old 10-31-2010, 10:56 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
carb sticking?
I have and edlebrock 1406 and it sticks when its closed. but once you pull it off idle it will be fine as long as you always have a little pressure on the throttle. Its almost like the butterfly's are dirty and sticking but they dont look very dirty. What else could cause this?
Old 10-31-2010, 11:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb sticking?
Worn throttle shafts?
Old 10-31-2010, 11:44 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: carb sticking?
is there a way to tell for sure?
Old 10-31-2010, 12:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: carb sticking?
Does it stick when the engine is off? Is there any play in the shafts?
Old 10-31-2010, 12:52 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: carb sticking?
it does stick when the engine is off and i will check the play in the shafts. Are you able to buy new shafts?
Old 10-31-2010, 01:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: carb sticking?
You can replace the shafts and bush the body, but it's a bit of work.
Old 11-02-2010, 09:09 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: carb sticking?
there is some play not alot im gonna take it off and make sure its super clean before i go any farther.
Old 11-02-2010, 09:37 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: carb sticking?
i got it figured out now found a piece of the linkage that was bent and causing it. Might of happened during shipping not sure.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
customblackbird
10-01-2015 04:30 PM
Wylecoyote08
09-08-2015 08:26 AM
rjcme
09-05-2015 01:23 PM
Quick Reply: carb sticking?
