OBD Diag Data Pin E Missing? (for ALDL)
Car: Pontiac Firebird ´87
Engine: L69 305
I read this Nokia Phone Cable as ALDL Cable Thread here:
https://www.thirdgen.org/forums/diy-...-usb-aldl.html
and wanted to try this before buying a ALDL Cable, as I am sitting in europe and the shipping costs nearly the same as the cable.
When I was sitting in my car I mentioned that there is no E Plug ?
If I use the D Plug nothing happens.
Short Wire A + B does work well (error codes)
I am running a Pontiac Firebird 87 which was equipped with a LG4 and E4ME cc carb. Now it is a L69 also with a cc carb.
http://img.picshare.at/1413302855_obd.JPG
Is this correct? Could not find any notes on this plug ?
Car: check
Engine: check
Transmission: check
Re: OBD Diag Data Pin E Missing? (for ALDL)
Place a 10K resistor between ALDL A & B and do a key-on, engine-off. Look at the SES light, if it flickers then ALDL pin D is the serial data. The drawings for this car don't show a pin E for ALDL data.
Actually, they make no mention of an ALDL data stream. The ECM may bit-bang it out of the SES light pin of the ECM.
RBob.
RBob.
Engine: L69 305
A+B Flashes with Key On
A+D (A gnd and D Data) - nothing happens with Key on.
Maybe I can check with a friends ALDL Cable today if its working at all.
Thanks for your help
gta892000
09-16-2015 12:37 AM
