New Motor, Dual fans killing Battery?
Old 07-20-2008, 10:23 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I just got my new 358 in and were running dual fans and one fans connected to
the ignition and the other fan runs to a fuse. But after two weeks its constantly killing my battery and I don't know if i should buy a new one or re-route the fan wiring. I got a new alternator about a year ago so i don't think it could be that.
Maybe its the wire to the fuse? doesn't one side run straight to the battery and the other is through the alternator. Any info would help!
Old 07-20-2008, 10:28 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: New Motor, Dual fans killing Battery?
You could leave both fans directly to the battery if you used a 30/40 amp relay and energized using the ignition.. I particularly don't like to tap into a power source off the ALT. The fans really don't need to engage unless the car in on anyway. I did see someone that ran a timing delay module in there setup so it would run upto 5 minutes after all power was off to help cool the engines..
Old 07-20-2008, 10:30 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have the jegs dual fan deal for like $189, the relay they gave me kept kicking off one of the fans for some reason, should i buy a better battery?
Old 07-20-2008, 12:35 PM
ibmtech's Avatar
Car: 1987 IROC-Z
If you have had your battery load tested and there isn't a problem, you can eliminate that as a problem right off. I wasn't sure what you meant by kicking off one of the fans though.
Old 07-22-2008, 07:53 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Well i had my battery load tested and they said it was good, i never saw it go under 11.5 volts/amps?
But one of my fans is running off a relay which runs to the battery, and the other fan runs off the fuse box where it points to radio, but there is no fuse other than the fan wire.
But its draining the battery FAST. the fans draw 24.5 amps.
can you run a fan directly off the battery if you use a relay?
Old 07-22-2008, 08:04 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
my fan is just ran off the battery with relay and fuse somewhere in the mix with a switch in the car...
Old 07-23-2008, 09:09 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Is the alternator just not producing enough amperage for the fans? I don't know how much left over power a stock alternator produces
Old 07-23-2008, 09:26 AM
ibmtech's Avatar
Car: 1987 IROC-Z
I still don't understand something. Have you hard-wired one or both of your electric fans into the ALT wire? If you have, I personally think this is a bad idea. The Alt's main purpose is to replentish the battery. The battery carries all the responsiblity for Electric storage and this is where you need to be wiring to or a junction block.. If your batteries are dying if the car is off, You already said you load tested the battery's. You need to isolate the problem where the energy draw is coming from. And if your fan(s) are hard wired to work even if the car is off, That would be a good place to start.
Old 07-23-2008, 01:00 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
By ALT you mean the main positive wire running to the battery?
If so yes, both fans are running off of a relay and some type of fuse, but then one branches off to the fuse box and the other runs straight to the battery positive. I'll get some pictures up tonight.
Old 07-23-2008, 03:07 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
its probably the alternator not producing enough amperage
Frozer!!!
01-19-2024 04:55 PM
customblackbird
08-15-2021 10:16 PM
Dialed_In
08-20-2015 01:45 PM
86White_T/A305
08-17-2015 12:16 AM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: New Motor, Dual fans killing Battery?
