Im looking to convert a switch
Old 04-02-2014, 05:35 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
So, I am making a little bezel for a couple of lights on my instrument panel. I need to convert the big fog light switch to a smaller one. Like the ones shown below. How can I do this without having any wires running to hot? Any help please. Thanks! Also, the best kind of switches suggested for this? I am running HIDs in the fogs if that makes a difference. I have to be able to fit 4 switches on there though. So they have to be pretty small. Thanks!
Attached Thumbnails Im looking to convert a switch-s1.jpg   Im looking to convert a switch-mh7jj1-4joozrbpsmnyjlew.jpg
Old 04-02-2014, 05:52 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Im looking to convert a switch
A switch is inline with the load. Wiring for a simple on/off switch is either:
+12 - load/light/etc - switch - ground
or
+12 - switch - load/light/etc - ground
with each "-" being a wire.
Or did you mean "too hot"? As in drawing too much current through the switch? In that case, you wire the switch to control a relay at low power, and the relay controls higher power to the light(s).
Check the power rating on the new switches you want to use. A good rule of thumb is the fuse supplying power to the switch is less than the switch rating.
Old 04-02-2014, 05:58 PM
Annihilate's Avatar
Engine: 5.0
Do you know the stock power rating of the stock switch?
Also, I was mainly confused because the stock switch has 4 little prongs. Why does it need so many? Shown here. How can I convert the wires from the 4 prong to a 2 or 3 prong?
Old 04-03-2014, 07:47 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
AustinThirdGen shows a 5 wire connection, middle right side of image.
You need two at a minimum:
Brown = +12V when the lights are on.
Brown/White = this supplies low power to the relay.
The others are extra, IF these are the same on your car:
Grey = light that is lit with the other dash lights.
Black = ground
Purple = light that is lit when the foglights are turned on.
Old 04-03-2014, 12:36 PM
Annihilate's Avatar
Engine: 5.0
[QUOTE=MoJoe;5741998]AustinThirdGen shows a 5 wire connection, middle right side of image.
Black = ground
/snip
So I don't need the ground hooked up? How many volts/amps should the switch be?
Old 04-03-2014, 05:18 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Ground - No. If you are replacing the lighted switch with a simple SPST (Single Pole, Single Throw = one circuit on/off switch) switch, then no. The circuit has the + side of the relay interrupted...
+12 to switch to relay to ground.
Switch should be a minimum of 12V, but could be rated up to hundreds. Amp will probably be in the 3A-5A range, with less than 1A being sufficient for this situation.
Old 04-03-2014, 05:21 PM
Annihilate's Avatar
Engine: 5.0
Perfect thanks.
Old 04-04-2014, 02:04 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Amps dont really matter for a switch that just activates a relay. Relays dont take much current to operate.
Old 04-10-2014, 02:32 AM
Annihilate's Avatar
Engine: 5.0
Okay, I don't have a brown/white wire. All I have is Grey, Brown, Purple, and Black.
Old 04-10-2014, 06:55 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
I'd say just use the brown wire for the low + supply to the relay. IIRC this is how/why the fog lights only work once you've turned the parking lights on (as well as with the headlights).
1992 Trans Am
05-10-2023 07:19 PM
GTAman
03-15-2019 11:40 AM
Azrael91966669
25
06-20-2017 04:04 AM
tcarlos13
Interior Parts Wanted
09-02-2015 07:29 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Im looking to convert a switch
