ZZ4 with Edelbrock water pump
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I'm just putting the finishing touches on my new ZZ4.
I'm finding that the ac/air pump bracket will need about a 1/4" clearance in two spots to clear the new Edelbrock water pump.
...Is this common?
...Is this common?
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i am having the same problem with my water pump not fitting with the serpentine bracket also. i bought used brackets off of ebay and i really dont know what they came off of. should i grind down the water pump or the bracket.
Engine: ZZ4 TPI
I ground the water pump; there was plenty of "meat" in the problem area...fits great now.
yea i guess that i am going to have to grind down the water pump. i had the water pump on before i installed the brackets and the damn brackets wouldn't bolt up. i was so peaed off that i was about to go back to the v-belt set up than a guy from parts told me that when he put the serp set up on his that he bolted the brackets first than the water pump so i removed it and than the brackets fit perfect i than seen that the water pump was hitting the bracket. go figure
Car: 1991 Z-28
Engine: 383 TPI
Re: ZZ4 with Edelbrock water pump
very old thread, but I just installed my new aluminum Edelbrock water pump yesterday and had to grind it down in 2 spots. Just for curiosity I did a search this am and found this thread. Thought I'd repost for anyone else out there having issues.
Engine: 4++,350 & 305 CIs
I had to do a lot of work on my E-water pump back when they 1st came out to make it fit the serp setups.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
so Edelbrock sells a reverse rotation water pump that is only going to be used with a serpentine setup and it doesn't clear serpentine brackets, and they haven't changed the design in over a decade???
Edelbrock is usually pretty good about stuff fitting like oem- which is one reason i like their intakes over other brands.
evilstuie
01-09-2020 08:29 PM
Chuck84TA
07-15-2016 09:05 PM
