Viper Powered 85 Z28
#201
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Re: Viper Powered 85 Z28
Don't be ridiculous. It's a wild project and if those mopar guys don't want to use these old viper engines, someone should.
#202
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
I'm putting a radial engine in my Z28. Everyone make sure to follow.
#204
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
you should be fine. My 521 Big block ford in my 87 formula 350 is alil bigger than that V10. Took some work but i made my own headers and a bunch of other stuff and it dropped right in lol.
Its hard to see how wide this thing really is but its massive. the valve cover is .250" away from the top left of the brake booster lol.
good luck with the swap! Its always better to be different!
Make up your mind,
#205
I'm not sure if I should connect a propeller to mine or affix a transmission
#207
RlCER and an American V8 are 2 different things. Wether in be a SBC, BBC, SBF,BBF,HEMI,Caddy BB yadda yadda they are all from the same type of American muscle family and therefore should be respected.
And yes my 521 BBF sounds meaner than your LQ9 can and will ever! My minds made up... american muscle for me only.
#208
Rotary engine can be found in (but not limited to) what I believe is a RX7 by mazda I think, no pistons looks like a triangular type of wheel that spins, very high revving but still sounds and looks like a RlCER to me.
Radial engine is an airplane engine with pistons its 2am and I've been up for 20hrs.
#209
Car: 93 240SX
Engine: LQ9
Uh sweet, it sounds "meaner"
Good thing thats the only thing it does "better"
There is a certain lack of intelligence contained within your posts, and a lack of logic as well it would seem.
#210
Honestly you want to get into this? What Does it do better? lets see, Its meaner, it makes prob at least double the power as your LQ9, It weighs just about as much as a fully dressed iron SBC, runs on pump gas shall i go on? It took more brains to figure everything out and to stuff it into a car that isn't even designed to take the same family of engines. Its driven on the street, car shows and then to the track.
So please tell me what yours does better? gets alittle better MPG? Big Woop!!!
Its one thing to attack a post (which i admitted to mixing up rotary and radial) but then to attack someones integrity. Why don't you go work on making your car "better" than mine and Im sure your other 4,000+ posts are just as useless as these are now.
Lets get some updates on the viper motor!
#211
Car: 93 240SX
Engine: LQ9
#212
Car: 93 240SX
Engine: LQ9
You do realize that to even "double" the power of a stock LQ9, you'd need to have it make 700 HP, right ?
Can you even count that high ?
Yeah, back to the viper motor ! Respect it ! its giant and makes 400 HP out of a miniscule 8.0L
Eeesh, this swap really is as terrible as I thought.
Goodness the 2.0 I took out of my car made 3/4+ that power with 1/4 the displacement, that is PITIFUL.
Let alone if we compared the weight of both, better RESPECT THAT, cause its got 8+ cylinders.
#213
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
isn't this someone Else's build thread? can we get some mods to cleanup the spill in aisle 6 here
#214
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Haha this guys seems to **** on every thread thats not the typical cookie cutter swap. Not sure if be gets bored, maybe ultimate troll, or is insecure so needs to talk down other builds to make himself feel better? Who knows its really annoying tho.
#218
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
#219
Car: '83 Sport Coupe
Engine: 360
Axle/Gears: 10 bolt 3.73 TrueTrac
I got a great deal on an electric golf cart. Stay tuned for my electric front wheel drive conversion thread!
#220
Car: 93 240SX
Engine: LQ9
This thread stopped being anything even close to anything resembling a "build" or "fabrication" long ago.
If only people who couldnt get either done couldnt start posting about it on the interwebs without being done first, and those that cant do either couldnt whine about those who can, and are realistic about it, on the internets.
#223
1 Post
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Same thing nearly happened to me here, under one of the 8 user names I've used since tgo started. I've been here from the beginning.
But I love these cars more than I love Fieros, and I have more experience with them. Plus they come with more headroom and more structural integrity. You wouldn't believe how much you can twist a Fiero chassis, just changing a tire using a floor jack on the rear bumper mounts. Also, the other Fiero forum was even worse.
#224
1 Post
The Viper swap would be cool except for cost, the Ram version makes little sense, but still holds more appeal than any BBC swap, the turbo LSx option makes the most sense and has the mos advantages, but there's still an allure to large displacement that even a turbo LSx can't kill.
#225
1 Post
Better to keep your mouth shut, or not post, and be thought a fool, than to open your mouth, or post stupidity, and remove all doubt. And you, sir, posted foolishness. Try research and keeping things in context.
diana227vegas
07-08-2016 12:27 AM
ambainb
04-25-2016 09:21 PM
