any body change their pedals to other than stock?
i have been thinking and looking for a set of pedals thats are not cheap. something of a better quality then the crap you can get from the local autozone. i came across these. don't know how they mount but they look good.
http://www.performancepedals.com/che...aropedals.html
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
Re: any body change their pedals to other than stock?
Check out this post, there is a picture with decent pedals
https://www.thirdgen.org/forums/inte...ml#post5954954
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Pffffffff it's something I step on every day, mine didn't have the rubber cover on it when I got the car, I went to a local skate shop and got some grip tape scraps and covered the brake pedal with that. It's real nice when it's raining. Much better than rubber. Those ebay specials sure do look nice though.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Function > looks
I've tried a few aftermarket pedal sets and have found I slide off them easier than the stock rubber.
I'd love to find a set that grips my boot... and that 'grid' style in the link the OP posted look perfect...
Engine: 5.0 Tbi
If your looking for fictional above all else, stop in a skate shop, 17th street, coastal edge, anything like that, and ask for some grip tape scraps or buy a cheap roll. It's amazing how well it works.
i want performance and looks..... i'm making everything else inside look nice. might as well have some cool pedals too.
I believe the flat part, which is what we consider the pedal is just lightly welded to the arm. Why not grind that off and weld on a slab of stainless that has been dimple died upwards. Could look identical to some I've seen online and in auto parts stores. Could also use aluminum but you would need a 90* bracket on its back to bolt to the arm.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I could see using nice pedal's like those.
Car: 1985 IROC-Z
Engine: 383
I have the black anodized ones from Performance Pedal. This is the only picture I have right now, if you want a better one let me know and I'll snap it tomorrow.
How about a set up that makes heel-toe manipulation easier?
My GMC Canyon it was pretty easy, I have a heck of a time in the T/A, they are too far apart and sit at uneven levels which is even worse when the brake is pressed.
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
