K-member LSx swap 82-92 Camaro
Old 11-28-2015, 08:03 AM
MustangEater82's Avatar
I have done a little bit of research and was curious for any additional input in case I missed some.
My goals, not a DD, but street/strip/occasional track day. I am all about making sure this car is rigid(t-top car) I also have concerns of the stories of cracked k-members. Weight reduction is nice but not critical. I currently want to keep it kind of simple converting to an ls1 for now, but eventually maybe go into a coilover/tubular a-arms, etc... I made a list of some of the K-members I know of out there and the pros/cons. Let me know if you guys have input or see if I have anything wrong.
Honestly the road race UMI, and the PAracing are at the top of the list.
1st
UMI performance..
1982-1992 GM F-Body Tubular K-member, Factory Springs, Road Race
Pros
-havent heard any complaints
-additional strength "dual tube construction as well as extra tubing and gusseting in critical areas"
-accepts factory suspension and A-arms
-Removeable upper spring pockets if I wish to go to coil-overs in the future or go back.
-has everything I need but ls1 mounts to go
-offers expandability in the future to get to coil overs, aftermarket control arms, and add AC.
Cons
-need to relocate AC for ls1 conversion. Not a total CON, I might hold of on AC for now and just get car up and running and get that fixed later and decide on a full setup. They suggest the www.kwikperf.com pulley setup.
-to get my project going...
Price with 10% off now for k-member and mounts... $685 plus free ship.
http://umiperformance.com/catalog/in...roducts_id=732
http://umiperformance.com/catalog/in...roducts_id=692
2nd
UMI performance again.
1982-1992 GM F-Body Tubular K-member for LSX Engines, Factory Springs
Pros/Cons
-Same as above, but doesn't have the additional strengthening of the road race version, no need for extra Ls1 mounts
Price with 10% off for k-member, $570
http://umiperformance.com/catalog/in...roducts_id=624
3rd
BMR suspension
Pros
-havent seen complaints
-mounts included
Cons
-not sure if it works with factory ls1 AC or not?
-only works with aftermarket A-arms, another $300-500 now
-needs upper spring perches for factory setup. another $90
-To get my project going...
Price $540, Spring perches, $90, Control arms $300-500.
$930-1130 (bit pricey having to get A arms now)
4th
PA Racing
Pros
-Road race option for $150
-accepts factory ls1 AC and lines
-accepts factory A-arms with minor mods(have to look into what, don't mind some minor grinding)
-heard no complaints on product
-Seems to have what I need for $650 (depending on A-arm moding)
Cons
-heard customer service and lead time is bad. (not in a rush so not too bad
-not sure if spring perches are modular, but can cut them out if need be if I ever go to coil overs.
-I doubt free shipping
$650 for what I wanted. Maybe
http://www.paracing.com/racingstore/...roducts_id=145
5th
Spohn Racing
Pros
-allows stock A-arms
-brake line mounts(only one that lists it)
-accepts AC lines
-Cheap
Cons
-everyone says this thing sucks and has tons of issues and engineered poorly
-calls out for extra bracing for street driving and says will interfere with ls1 alternator. Is it weak?
$540 + $10 shipping with 15% off deal.
http://www.spohn.net/shop/1982-1992-...-LSX-Swap.html
Old 11-28-2015, 07:33 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: K-member LSx swap 82-92 Camaro
https://www.thirdgen.org/forums/ltx-...selection.html
post #2
Old 11-28-2015, 08:26 PM
WTR388's Avatar
Car: 87 Trans Am
Off topic but... What kind of plane do ya have?
I was lucky enough to spend my summers as a kid on a grass strip on an old farm and love homebuilts... An RV4 is hopefully in my future.
Old 11-28-2015, 08:40 PM
Ok kind of goes along with what I was thinking. UMI and PAracing at the top. If the factory A-arms appeared to just slide right in I might have gone with PAracing. Might just do UMI road race, and deal with AC later with relocation pulleys, also gives me some variety allowed on an AC compressor.
Old 11-28-2015, 08:46 PM
LOL, the link is dead, and my sig is old. I am not lucky enough to own one. I work for an aircraft manufacturer. It was a pic of the first one we built, I spent probably a year, with 50-60 hour weeks on it. Probably the most time I ever worked on a single machine. I would love to do a home built(at least by a half finished project and finish it) but planes, even home builts are so damn expensive.
Either way that was a few years ago... most recent plane of interest I helped build.
https://pbs.twimg.com/media/CQPfGldUYAEbbHE.jpg
Old 11-28-2015, 09:32 PM
WTR388's Avatar
Car: 87 Trans Am
That's a slick paint job.
Buying a partially done kit is the way to save big $, as long as the guy was doing the work properly.
I was an army medic (canadian) for nearly 9 years, now I'm in training to be an Aircraft structures tech which involves the life support equipment, refinishing, composite manufacture and repair, metal work, parts machining etc. Pretty sweet trade actually.
And to stay on topic, if I were to have used an aftermarket K-member it would have been the UMI road race version (might get used on my second build for a "road legal" road race camaro)
Old 11-28-2015, 09:38 PM
Yep I am an A&P mechanic with FCC license... I do final testing and troubleshooting. I lean more towards the Avionics/systems/wiring side. It is a good trade. Stick with composites, its all I see all day long on the Plastic fantastic almost all electric Jet 787!
as for on topic I was leaning that way, almost bought it yesterday but figured worth a post to see if there was any other input.
Old 12-01-2015, 07:00 PM
I ended up going with umi road race k member and ordered some subframe connectors too. Will give an updates on it one day.
Old 12-07-2015, 02:43 PM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
He lives!
I'm going to go with PA Racing for my swap.
Old 12-07-2015, 03:00 PM
Originally Posted by Mdenz3
He lives!
Yep I do! Third gen still doesn't though.
I thought about PA racing. Long term might have been better do to AC provisions and I will eventually do A-arms. But I went umi as it was on sale, good unit, works with factory A-arms for now, and going with a kwik performance pulley setup let's me go 3rd or 4th gen compressor. For now I just want to get the heap going back on the road. I look can do "weekend" projects of a-arms and and getting the AC figured out in the future.
Slowridr
35
12-16-2015 09:09 AM
KED85
10-03-2003 08:57 PM
five7kid
10-07-2002 02:11 PM
Mark A Shields
Theoretical and Street Racing
04-17-2002 09:43 PM
Quick Reply: K-member LSx swap 82-92 Camaro
