4th gen rear brake issue
Old 02-08-2012, 07:35 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I just finished my rear swap and looked at a few rearends and the calipers were mounted on the front. Is that correct? I have seen them both ways. Which is correct? I hope I don't have to take it back apart again.
Old 02-08-2012, 09:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen rear brake issue
LT1 (93-97) on the rear. LS1 (98+) on the front.
JamesC
Old 02-08-2012, 10:34 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
So the rear end is out of a 98 Z-28 stick car and it didn't have brakes on it so I bought a set off a 97 Z-28. That being said I will assume that the housing has nothing to do with it and I need to change it around. Am I correct?
Old 02-09-2012, 06:58 AM
JamesC's Avatar
10-bolt axle flanges are all the same, so with LT1 backing plates you'll be able to mount the 97 set-up. To install the backing plates, you'll have to remove the axles themselves.
JamesC
Old 02-09-2012, 07:48 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
So am I ok with the LT1 brakes mounted in the LS1 position or do I need to take the axels back out and move to the brakes to the back instead of the front where they are now?
Old 02-09-2012, 07:58 AM
JamesC's Avatar
I'd imagine that the bleeder screws and parking brake cables would be in the wrong position mounted like the LS1's. And as I mention, the LT1's were designed for the backside.
JamesC
Old 02-09-2012, 08:07 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Thanks JamesC I will take it apart and change it around.
Old 02-09-2012, 05:31 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
I changed everything around and I hearing the pads rub on the rotor pretty good. I checked the axels with th car off the ground and they are true. what else would cause that issue?
Old 02-09-2012, 05:40 PM
JamesC's Avatar
There's always some drag.
JamesC
Old 02-09-2012, 05:50 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
I understand that but I can hear it in the car with the windows up, it's pretty loud.
Frozer!!!
01-19-2024 04:55 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
kyleb24
08-15-2015 08:24 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: 4th gen rear brake issue
