good clutch brand?
Old 10-07-2014, 12:49 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
good clutch brand?
hi, i am putting a 400 sbc in my 90 rs camaro with a t5 trany i am using a 153 tooth flywheel out of an 84 camaro so it is a two piece rear main flywheel to match my crank as well as a counter weight plate that goes between the flywheel and the crank so i can externally balance it. i know what you are thinking, "the t5 trany wont hold up to a 400" yes i know i should be using a t56 but i am a collage student and this needs to be a mild budget build. but i dont want to go skimpy on a good clutch. are there any recommendations as to which clutch brand you guys prefer? thanks.
Old 10-08-2014, 12:25 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: good clutch brand?
I am a big fan of Mcleod
Old 10-08-2014, 07:48 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have been happy with my spec clutch. The t5 will handle the 400 if you don't miss 3rd and don't launch it a lot.
Old 10-09-2014, 11:34 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I also have a McCleod, but it's a bit more than the rest...
There is a 11" (10.95) clutch that works, I and a few other members use it, I think I got both for about $420...
Info from McCleod...
"Yes the 10.95” pressure plate in the part number 360710 will work on the 10.5” pattern your flywheel has. The 260871 has been discontinued and is currently replaced by part number 260571"
The new part number for the disc is a dual friction clutch disc.
Good for 500 HP
Old 10-12-2014, 01:35 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
A relining with the right material will last. My friend's car with 408 and T5 got a lot of miles with a ceramic reline of a stock style clutch. What they used did eat into the flywheel more than a stock organic.
Old 10-15-2014, 11:41 AM
Granny's Avatar
Install one of these DIY Clutch Tamers if you use anything more aggressive than a stock organic lining. Very inexpensive, you will be surprised at how much more power you will be able to throw at that T5...
DIY Clutch Tamer
Old 10-15-2014, 12:53 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I really like the Spec stage 2+ for a good gripping daily driver clutch.
Old 10-15-2014, 01:28 PM
83Z28/L69's Avatar
Car: 83 Z28/L69
Engine: L69 305H.O.
This is a pretty good budget clutch, I had it handle my 300 rwhp just fine.
http://www.summitracing.com/parts/ra...t/model/camaro
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Reddeath210
10-06-2015 08:20 AM
86IROC112
08-17-2015 02:00 PM
TreDeClaw
08-14-2015 06:58 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: good clutch brand?
