88 2.8 firebird with predator body kit $400
Old 04-01-2010, 08:18 AM
aaron0991's Avatar
I just bought this, the engine is a little rough but other than that there is not too much rust and the interior is mint except for the seats. The body kit is in good condition, the back is deformed a little bit from the exhaust. The front is missing and i have found the site, the only problem is that the front piece is missing and i cant buy it.
There is a little green toggle switch that I have no idea where it goes to, for some reason when it is flipped the plugs get fouled out and covered in oil.
When i drove it home it drove fine other than the driver side brake freezing up. Other than that it handled fine.
Old 04-01-2010, 08:52 AM
aaron0991's Avatar
Re: 88 2.8 firebird with predator body kit $400
The only other thing is that the engine is high mileage and needs to be replaced sooner or later, im either looking at just building a new 2.8 with some basic performance enhancements like cams, polishing, and some dress up parts. Or doing a 3.4
Old 04-01-2010, 10:08 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Nice car! I do like the body kit too, to to in your face or crazy. It looks like something that came out of the 80's so it fits the car well.
Like the TA hood too, I've wanted to get one of those for my V6 for a while but haven't been able to find any local.
Old 04-01-2010, 10:15 AM
aaron0991's Avatar
lol if you lived loclally id give you the hood. Its all banged up and has some rust patches.
Old 04-01-2010, 10:29 AM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
wish my motor looked like that...
Old 04-01-2010, 11:55 AM
aaron0991's Avatar
is yours bad?
Old 04-01-2010, 12:05 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Better look out. Someone else might take you up on that now!
Old 04-01-2010, 01:03 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I had that kit for a few years. You're missing 3 pieces up front. Probably easier to just use regular TA gfx up front. Might even look good.
What's the spoiler from?
$400.... So much for "collector value".
Old 04-01-2010, 01:16 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
It's a 60/6 there's no such thing as a 60/6 that needs replaced.
Rebuilt, maybe, replaced, not likely,lol.
Old 04-01-2010, 01:26 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Yes there is it's called the early 2.8s with the small crank journals . The cranks in the early 2.8s are prone to breaking .
Engine: 3.8, 3.4
Ok you're right, but other than those there isn't, and his is an 88 so his is fine,lol.
Old 04-01-2010, 01:49 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Yeah I would keep it and freshen it up or do a hybrid or 3.4 swap . I may get a 6.0 for a Lsx swap or freshen my 2.8 up or do a 3.4 swap . I have to many options to chose from .
Old 04-01-2010, 01:51 PM
aaron0991's Avatar
Previous owner ragged on it pretty badly. Its going to need to be rebuilt if i keep this one.
Old 04-01-2010, 01:53 PM
aaron0991's Avatar
I'll look into the gfx, and im not sure what spoiler it is.
Old 04-01-2010, 01:59 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
If it is wore out and in need of rebuild look for a 3.4 to drop in and use your intake from bottom to top with the 3.4 injectors IIRC and it will run fine . I once built a 2.8 from bottom to top all new parts and had the heads checked and all that and with all new parts other than the heads and block and the sheet metal parts and carb and intake and I reused the harmonic dampner and the flexplate . I had about $1,100 to $1,200 in it afterwards .
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
you should consider dropping a bigger engine ... a 5.0 or 5.7 would be nice..
Old 04-01-2010, 02:57 PM
aaron0991's Avatar
to put a 5.0 in it wouldn't i need a whole new wiring harness.
Old 04-01-2010, 03:21 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
yes I do believe so along with computer and prom... with a 3.1, I think all you would need is a prom... not sure though...
Old 04-01-2010, 06:15 PM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
with a 3.1 all you need is to reuse the throttle body 3.1 is just a bored 2.8 with a different IAT and TPS sensor plug. IIRC
Old 04-01-2010, 07:15 PM
aaron0991's Avatar
so i can just get a 3.1 and only have to reuse my tb. no sensors or anything.
Old 04-01-2010, 08:15 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
is yours bad?
not to long after i first got it, all sorts of nests and leaves in it. Not to mention just the overall condition of it. Got it for free pretty much though.
Old 04-01-2010, 08:40 PM
aaron0991's Avatar
thats what mine looked like before i cleaned it. got it with the pressure washer
Old 04-01-2010, 08:44 PM
ncmail's Avatar
Car: 89 FireBird
Transmission: AUTO
the spoiler is off of a 1988 special appearance package I am restoring one now and need a spoiler if you are interested in selling PLEASE contact me I have the fender flares for the appearance package and NEED the spoiler mine is falling apart.
Old 04-01-2010, 08:49 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
if you want to dress up the engine, make sure you check out this thread I started...
https://www.thirdgen.org/forums/v6/5...ppearance.html
by the way, NICE CAR!!! you stole that thing!
Old 04-01-2010, 11:15 PM
Engine: 3.8, 3.4
He really did, I payed twice as much money for half as much car But at least it's kept me busy,lol.
Old 04-02-2010, 08:04 AM
aaron0991's Avatar
I really like the spoiler so no chance of getting rid of it for cheap.
if i can get my 2.8 to look like that im going to keep it.
Old 04-02-2010, 08:20 AM
Lectoid08's Avatar
Car: Camaro
Engine: V6
I would like to but this in my 3.1 rs
http://www.crateenginedepot.com/stor...30-P25C56.aspx
I thank this would make a nice cruiser.
Old 04-02-2010, 08:32 AM
aaron0991's Avatar
ouch 1,800 for that motor wont work well on a poor mans budget. I think im just going to make this into a nice looking cruiser. If i want to go fast ill just jump on my fully restored 1984 kawasaki GPZ 750 turbo. That thing is scary fast for how old it is.
Old 01-26-2012, 03:27 PM
janson33's Avatar
Car: 1988 pontiac firebird 2.8 v6 base
Engine: 2.8 v6 173
Transmission: automatic
Axle/Gears: stock
how the hell did u get that top piece so shiny? mine is all grey and rough,just like urs in the "before u cleaned it" pic.
Old 01-26-2012, 03:31 PM
58mark's Avatar
You talking to me?
I posted the link for the "how to" thread
Old 01-26-2012, 03:42 PM
janson33's Avatar
Engine: 2.8 v6 173
Axle/Gears: stock
You talking to me?
No I was asking Aaron but I guess I may as well look at it thx
Old 01-26-2012, 06:55 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I wonder how long that would take with a dremel.
Old 01-26-2012, 07:06 PM
58mark's Avatar
polishing, or sanding?
Old 01-26-2012, 07:10 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Really just to smooth it out a bit since its so rough to start with, id probably do the finer sanding and polishing by hand. Id really like to try this since its winter and i have the stuff off the car right now. The only thing holding me back is figuring out the best way to go at it.
Terrell351
06-13-2021 01:13 PM
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
toronto formula
11-10-2015 06:17 AM
E Rod
08-28-2015 05:17 AM
lakeffect2
08-23-2015 08:44 AM
Quick Reply: 88 2.8 firebird with predator body kit $400
