Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Airgap
Old Mar 29, 2003 | 04:29 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Airgap
Are there 2 diffrent airgaps ?
Ive noticed that the 2 openings
on the top of the manifold can be either
oval.. or one oval.. the other squarish..
am I right?
If yes are there diffrences
within powerband and performance ?
Old Mar 31, 2003 | 09:08 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
do you mean like the two intakes shown in these pictures?
on the topis a Performer RPM Air Gap for Vortec heads...on the bottom is a regular Performer for Vortec heads.
if you ae talking about the difference in carb mounting locations, then these two pics show the two different mounting patterns. the air gaps have a "square bore" mounting pattern, while the perfomers have a "spread bore" pattern. BUT the performer has two sets of bolt holes...so either a square bore carb or spread bore carb can mount to it.
for more pics, go to the site in my sig, then go to "tech" then go to "edelbrock intake comparison".
as far as i know, the air gaps come ONLY in square bore. but im not sure...look them up on edelbrock's web site.
hope this helps...
-brian
Old Mar 31, 2003 | 09:25 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
yup one is an air gap, and one isnt
Old Mar 31, 2003 | 01:57 PM
Spectre's Avatar
Engine: 3.0L/183
theres one
Spectre's Avatar
Engine: 3.0L/183
other
Old Mar 31, 2003 | 01:58 PM
Spectre's Avatar
Engine: 3.0L/183
the left inlet is squarish I find..
Old Mar 31, 2003 | 02:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
well...those two intakes are both air gaps...but one is for vorte heads, and one is for standard heads.
BUT, that makes no difference in the mounting of the carb or adaptor plate.
the second picture is just distrorted. they are both going to be the same. they willl look like this...
-brian
by the way...all of the pics i am posting are ones that i took of my own intakes...not edelbrock ones or anything.
Old Apr 1, 2003 | 03:36 AM
Spectre's Avatar
Engine: 3.0L/183
Ahh that explains it lol..
thanks
Old Apr 1, 2003 | 07:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
ummmm why does it say "HITHERE" all over the place in my replies????
that is really wierd...
-brian
Old Apr 1, 2003 | 07:09 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
well, apparently, HITHERE am now an administrator now too...cool
must be HITHERE problem with the boards...
Old Apr 2, 2003 | 11:37 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Originally posted by Spectre
other
Look at the hole by the water neck. it points straight up where as the other airgap one is at an angle. Also that polished one is $100 cheaper then a regular airgap. Seems weird, sure, it's not a knock off.
Old Apr 2, 2003 | 12:12 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah that does seem like it is not a genuine air gap. on the edelbrock polished intakes, you can still see all of the "edlebrock" casting stuff on there. on that one, you cant.
how much is that one that you posted? its a hundred bucks cheaper than a regular AG? if that is the case, there is NO WAY that it is a "real" one.
-brian
buckshot63
Sep 10, 2015 09:15 AM
klumb15
Carburetors
Oct 10, 2004 06:46 PM
25THRSS
Dec 10, 2003 12:26 AM
foney_email
Carburetors
Oct 14, 2003 05:18 PM
Daemorok
Aug 26, 2002 02:11 PM
