Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD-6AL rev problem??
Old Nov 12, 2000 | 02:35 PM
ONEFORMULAOVERALL's Avatar
2 anyone w/ a 6AL did u ever have a prob. with the tach dropping 2 0 after it hit 3500 rpm? i think my rev limiter shorted out but i want 2 gain reviews before i contact msd.
if futher explanation is needed let me know
thanx....
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 4INCH PIPE 2 FLOW,
MSDDIST,6AL,8MMWIRES.
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.73 AND SPLINES,TUBE FRAME CONNEC
PST KIT.1LE BRAKE KIT! MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 109.75MPH
Old Nov 12, 2000 | 02:44 PM
theformula's Avatar
Be more specific.
'92 Formula
305 TPI
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
Old Nov 12, 2000 | 08:38 PM
ok here it goes. running fine till...
awhile back i had a coolant temp,idle,and cooling fan problem. i was driving 2 the city going about 85mph then all of a sudden my mph gauge went 2 o the car diseled and it did this about evey 1 to 2 sec. the more i gave it gas the more it shimmyed then died i could not restart. after having towed back to the shop i found that my ecm was not registering and bought a new one. thought problem solved. nope it did it again but now i started noticing that my dr side fan which i have hooked 2 toggle switch would not function and the idle was fluctuating,1200 2 400 rpm and coolant temp rose in a short time. i then went to the relay switch and replaced it. still had the problem finally i retraced my steps and with a test light found my (dumba$$ getting pissed off and not paying attention) problem the relay fuse link that runs off the battery that branches off 2 run power source 2 the relay switches and ect.. was barely held on by a thread. after sodering everything a-ok. now the question is did i possibly surge the unit(6al) while i tried fixing the prob? now of course it sill acting up but i have not lossed power or shift points (automatic) it just drops 2 0 after it hits 3500 and then when i manul shift 2 second it picks up about 2600 thn falls after 3500 then the same 4 3rd 4th and 5th.
what the hell!!
thanx guys hope that put things in a little more prespective.
Old Nov 12, 2000 | 09:29 PM
theformula's Avatar
Possibly it could of been damaged. Any sudden "volt" or increase/decrease in electricity to the system can damage the MSD box. They do not even recommend getting your car jumped.
Call MSD, or email the tech Joe at jlapille@msdignition.com
good luck
'92 Formula
305 TPI
Old Nov 12, 2000 | 09:42 PM
thanks 4 the info
i'll keep my finger crossed
Old Nov 14, 2000 | 05:50 PM
darkside's Avatar
I have the same problem on my automatic. When I installed it the instructions said there was a wire to bypass, somewhere on the firewall if this was to occur. I have looked and looked and could not find it.
Hope that helps.
1990 Formula 350, dual cat, aluminum driveshaft, AC delete, TES headers, Flowmaster, K&N 1000CFM, MSD, Hypertech, 3.73 gears, ROH 17x9.5 x (4)
Old Nov 15, 2000 | 04:34 PM
Thanks 4 the wire info!
i also saw on your sig u run 17/9.5 roh did u have any problem w/ the fender well? did u have 2 customize it at all
thanks 4 the info again
Old Nov 15, 2000 | 07:00 PM
darkside's Avatar
No customizing of anything...they bolted straight up and I even have 1 1/2" lowering springs.
Old Nov 20, 2000 | 04:01 PM
MSD tech's Avatar
ONEFORMULAOVERALL,
There is a tach filter inline on the tach wire(white wire) with in 1-2 feet of the coil. This will be a small black cube about 1 inch square with a white wire going in and a white coming out. Unplug the two white wires at the filter and plug them into each other. This will allow the tach to function again. If your car does not have a filter(which some do not) you will need the tach adapter part number 8910. If this is the case e-mail and make reference to this web page.
Thanks,
Joe
MSD tech
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
IROCtometal
Sep 9, 2015 10:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
