Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Door pin kit from TDS is awesome!!
Old 10-16-2006 | 08:02 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Anyone who has sagging doors owes it to themselves to install the TDS upper door pin kit. My driver door was sagging BAD, I had already put new lower pin and bushings in- whigh did not even help. I didn't exactly like the idea of paying $75? for 2 bolts and bushings, but it was definatly the best money I have spent on my car so far. Fairly easy to install, great customer service and worth twice the price.
I would add to the instructions that the easiest way to grind the old pins out- for me- was a dremel grinding stone instead of the cutoff wheels. I break waaaay too many of these wheels when I tried to use them.
Thanks Lon and TDS.
Old 10-17-2006 | 12:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Glad to hear it worked out for you. I use the fiber-reinforced cutoff wheels. They last longer and are less susceptible to breaking. Sometimes I'll use a fiber-reinforced one with a couple of the non-reinforced ones when I'm feeling cheap.
Lon
Old 10-17-2006 | 04:12 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
You mean stacking them together? I never thought of that, I bet that would work pretty good. I broke 3-4 of the regular cutoff wheels before getting half way throught the first pin, But I seem to do that everytime I try to use them. I did completely use up a 3/4" grinding stone, but I didn't have to change any more cutoff wheels. It seems to take me longer to change them than it does to break them in half.
Thanks again, I love being able to shut my door like a norma person.
Old 10-17-2006 | 07:47 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
so you're telling me that after this fix... you no longer have to slam your door? I would love that so much. I could NEVER quietly close my door for the stealthy escape.
i constantly have to make the passenger shut it again too. Especially my wife. I'll just know by the sound it made as it shut, and be like "your door isn't shut all the way."
"Yes it is."
"No it isn't, I don't care what it looks like that door is not shut woman, shut it."
"It IS shut."
*bump in the road*
*insane door rattle*
"Oh, maybe it's not shut all the way..."
"YOU'RE TWISTING UP MY CAR WOMAN"
Old 10-17-2006 | 07:52 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
my driver door was sagging bad enough to rub the rocker panel gfx all the way across, the pin jit fixed it as good as new.
Do a search for door hinge or pin or somthing like that and you will see tons of posts on this.
Lonsal is the authority on this, I am a very satisfied user.
Old 10-23-2006 | 12:41 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
"Yes it is."
"It IS shut."
*bump in the road*
Rofl! This made my night in the humor department.
Old 10-23-2006 | 08:44 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
That is so funny.......BUT true.........
Old 10-23-2006 | 09:38 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Another satisfied customer
Old 10-23-2006 | 09:50 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
I bought these in the spring. Awesome product. Greaseable ones. Greatest product ever!
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1Aauto
Sponsored Vendors
08-26-2015 02:14 PM
soarestransam
08-24-2015 08:15 AM
Out-Cast
08-23-2015 06:33 AM
BlackTopKing
08-19-2015 12:13 PM
Quick Reply: Door pin kit from TDS is awesome!!
