Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Mini starter
Old May 8, 2007 | 12:40 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Mini starter
Hey guys,
I have Hooker Long Tubes and an aftermarket oil pan. I purchased a pro-comp mini starter from Ebay, and regardless of how you clock the starter the solenoid will not clear the oil pan. Which aftermarket starters are you guys running?
Old May 8, 2007 | 02:15 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
Re: Mini starter
I use a Powermaster XS starter for 168 tooth flywheels, and it fits fine between hooker super comps my oil pan. It's small enough for me to slip it between the frame and the headers and install the starter with the headers and exhaust bolted up.
Old May 16, 2007 | 11:18 AM
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
Re: Mini starter
i run a summit brand high torque mini starter. it fits fine but i'm only running hooker shortys and stock oil pan.
Old May 17, 2007 | 08:11 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: Mini starter
I am using a Proform Mini Starter 153/168 tooth.
Old Jun 3, 2007 | 04:35 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: Mini starter
hey?
whats the part# of the powermaster XS mini starters? are they high torque? I have 153 tooth fly... also did you have to shim or did it just bolt right in?
Old Jun 8, 2007 | 11:59 AM
Re: Mini starter
Just an update, I purchased the proform mini starter, it bolts right up. The thing is TINY! I can rotate it 360* between my kicked out oil pan and my hooker super comps. Very impressed .
Old Jun 8, 2007 | 01:40 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Mini starter
This is what I am buying, MSD's APS Mini High Torque Starter
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 12, 2007 | 07:46 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: Mini starter
Im using the gm high torque starter. It can handle up to 11:1 compresion and comes with a bow tie one there! I am very happy with it and would recommend it.
Rabi C.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
