Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Lower Control Arm Relocation Brackets
Old Dec 25, 2007 | 05:59 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I have been wanting buy these for a while but after some research that missed when choosing my sfc"s i figured it wouldnt hurt to ask which company makes the best part thanx for any and all help...Charles
Old Dec 25, 2007 | 06:17 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Lower Control Arm Relocation Brackets
i have some umi bolt in's i like em and they work well
Old Dec 25, 2007 | 06:21 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Only one's I've ever used are Spohn"s with no complants
Old Dec 26, 2007 | 01:49 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I plan on getting the weld in kind and the only difference i can see is price,am i correct?
Old Dec 27, 2007 | 03:08 PM
86 IROC's Avatar
You got it, that and weld ins don't come powder coated. (not a big deal) I run BMR's on my 2000 and J&M Hotparts on my 91'. The BMR's seemed to fit a little better, but that could even be manufacturing tolerances between vehicles. BTW - I have bolt in LCA brackets on both cars. I found the J&M's on eBay at a great price.
Old Dec 27, 2007 | 03:59 PM
Bad5OGT's Avatar
Car: 1986 Ford Mustang GT
Engine: 5.0
What is the point of using the brackets? I mean, what advantages does it give?
Old Jan 10, 2008 | 12:28 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
makes the car plant the rear tires which in term picks the rear of the car up. changes the angle of the lower control arms, there is a sticky on this in the suspension forum. just put weld in relos from umi in about 3 days ago. car left harder then it ever has last night. pulled the wheels for the first time on a full weight street car 3880 lbs with me in it. definatly a great suspension upgrade.
Old Jan 10, 2008 | 02:23 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
What tires were you running to get that launch? I have the UMI weld-ins, still spins quite a bit with 245-50/16 BFG KDWHs.
Bill
Old Jan 10, 2008 | 06:18 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I have UMI and love them......
Old Jan 10, 2008 | 09:14 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have spohn's weld in's.
They are great. Definitly a must if you are traction problems.
Old Jan 11, 2008 | 02:37 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Is there an approx power ratio break that points to when they're needed? Although lower gears is going to place the available torque as more important than an hp rating.Hmmm. I thought the relocation brackets were just for lowered cars. I'll have to head on over to the suspension site and read the sticky- Nitro
UMI sure does make a top level product...........
Old Jan 19, 2008 | 04:52 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
The design is different depending on manufacturer. I bought the Spohns and should have tried someone else. Looking at pics the BMRs probably would have worked better for me. I had to remove quite a bit of material to get the e brake set up to clear the relocation brackets. BMRs design looks like it would have cleared with no modification needed.
Old Feb 2, 2008 | 03:36 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
top down solutions(TDS.net) sells a nice set manufactured by alston racing they run from the front where they bolt up right behind the transmission crossmember to the rear where they install just forward of the LCAs on the rear subframe. I went with these because they're a nice beafy tubing and I liked the bolt and weld in approach for convience along with them being the only ones i found that went directly to the subframes and don't interfere with running big exhausts for aftermarket suspension pieces.
Old Feb 2, 2008 | 06:30 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
This thread is about LCARB's not SFC's. Just FIY, not to be an ******* or anything
Old Feb 5, 2008 | 07:55 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The bolt ins have the extra mounting point. They can still be welded on as well.
Old Feb 9, 2008 | 12:16 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just installed UMI LCARBS last night. They were a great fit and very high quality part. I would def recommend them. I still am not hooking but they def helped improve traction.
Old Feb 9, 2008 | 01:18 PM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I'm sorry, what's UMI? I've never heard of that site.
Old Feb 9, 2008 | 01:21 PM
Car: 89 Formula 350
WWW.UMIPERFORMANCE.COM
Old Feb 11, 2008 | 01:12 PM
ckeene502's Avatar
global west has a great product. i have used several of their products...tourqe arms, alum. bushings and springs.
keene
Old Feb 23, 2008 | 02:45 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I just installed a set of edelbrock weld on lower control arm brackets they work great. they really help it hook up
Old Mar 1, 2008 | 08:11 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
quick question about the LCARB's- do you need to use the adjustable LCA's when you install the brackets or can you use the stock length non-adjustable ones?
Old Mar 1, 2008 | 09:16 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
works we both
Old Mar 1, 2008 | 09:19 PM
cool. thanks!!!!
Old Mar 1, 2008 | 09:45 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
I've heard about this suspension upgrade and its benefits at the 1/4 drags but does it hinder/help when taking turns/cornering?
Thanks for your input.
Rabi C.
Old Mar 1, 2008 | 09:48 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
i put a pair of umi relocation brackets in they were bolt in but i welded them in. excellent
Old Mar 17, 2008 | 03:16 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Im about to put some in myself from UMI. im also putting eibachs in so i know i need the LCARB's. has anyone installed these? it looks like part of the RB hooks up with the bottom shock so do you just lift up the car by the rear end and support it with the jack?
Old Mar 17, 2008 | 07:46 PM
krisb410's Avatar
Then you get a bit of added support from the shock mount.
Old Mar 20, 2008 | 10:22 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Is there any difference between the weld ins compared to the bolt ins.
Old Mar 20, 2008 | 11:08 PM
krisb410's Avatar
Weld in
Bolt in
The bolt in can also be welded on for extra support. I got the bolt ins, and I will get them welded on when I put the 4th gen rear in. Bolt ins also allow you to install them yourself.
Old Mar 21, 2008 | 11:36 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
these help even if you do not have wheel hop issues correct?
Old Mar 21, 2008 | 04:49 PM
krisb410's Avatar
From UMI's websight:
Lower control arm relocation brackets reposition your instant center by changing your lower control arm angle for improved traction. Relocation brackets lower the rear of the control arm up to 3", a must for all lowered vehicles to correct lost suspension geometry. By lowering your vehicle, you are changing the lower control arm angle allowing the rear mounting point to sit higher than the front. This will, in return, cause wheel hop and a great deal of traction loss. Lower control arm relocation brackets allow you to correct this angle and gain back much needed traction. On a stock height vehicle relocation brackets will also work excellent to eliminate tire spin and wheel hop by changing the vehicles instant center point. Note: Bolt-on relocation brackets will not work with aftermarket rear ends.
Lowered Vehicles: We do not recommend lowering a 3rd or 4th generation F-Body without lower control arm relocation brackets due to the compromise in the geometry on the instant center. Brackets will significantly improve instant center position, eliminate wheel hop and increase traction. Brackets installed will also help 60-foot times of .10 or better, lower ETs and increase track consistency--a must for all lowered vehicles!
Non-Lowered Vehicles: Product installed on a stock height vehicle will also see a great increase in traction by lowering the rearward angle of the lower control arm, allowing more force to be placed on the rear tires. Relocation brackets have two settings to allow the lower control arm to be lowered either 2" or 3", depending on your preference. Settings are placed in a correct pattern that will allow use of all OEM control arms or any aftermarket control arm (brackets do not require a longer control arm.) Brackets installed on a non-lowered F-Body provide a .10 or better 60-foot; reduction and an increase in track consistency.
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
