duration of a control module
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
so my control module took a crap yesterday, while on the highway cruising.
it was a accel cm that i bought about a year ago off of summit , i had one before that was a autozone duralast cm ,that lasted me two years and the only reason i changed it was becouse i did some ignition upgrades.
im kinda disaponted in accel right now ,
how long do this things usually last?
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: duration of a control module
Lots of people on here have said they had them not last very long.Stock one should do you just fine.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
its the ignition control module... i have had mine on for about 2 yrs and it was a daily driver. i took off a stocker to upgrade it with MSD blaster coil, mallory custom wires, MSD cap and rotor etc.
i would go with a petronix one if my accell decides to take a poop.
Car: 1987 Trans Am
Engine: LQ9/L92
To save some possible future grief, did you happen to apply the heatsink paste underneath when you installed the part? I know many (if not all) come with this stuff and it is highly recommeneded, since these parts can get warm. Otherwise, I ran my stock one up until the day I switched over to my carbed setup and had no issues in the 2 years I ran it.
Car: 87 TA clone
yea u have to put that dielectric grease on.... it heat sinks the modual so it doesnt over heat and fail. i even got a huge tube and added a ton so it dissapates better.
Car: 87 TA clone
does pertronix have the control modual for the remote mount coil distributer? it has the 2 weather pack connectors vs the 4-8pin ones. u got a part number?
looks like this
http://store.summitracing.com/partde...5&autoview=sku
looks like this
