Headers without A.I.R.
Guest
Posts: n/a
Hey guys, I know there is an article on here called Everything You Need to Know About A.I.R. but I couldn't find it. I am going to be buying headers here soon and it's much easier to find ones without AIR connections. Could I put on headers without the AIR and be just fine? No codes or check engine lights? I would replace the cats with AIRless cats if I went this route. I have a 92 Camaro 350 with of course MAP which I have heard can affect running with out the AIR. Thanks for the help in advance.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Headers without A.I.R.
Since the Emissions is a Federal item, there is no LEGAL way to not run the A.I.R. tubes in any state, regardless of the Emissions program.
However.....
In the States & Counties that do not test Emissions, they rarely look under the hood, despite the fact that they are supposed to. Can't check the Visual without looking.
However.....
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
CT looks under the hood (at least at the test place i went to). I am not running air on the headers i had (and now have another set without). The only thing that my test place really cared about was if i still had a Cat. After they saw that they ran the test and i passed.
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
the A.I.R system is separate from the ECU so no check engine light or any other problems like that the ECU won't know the difference .
Car: 1987 GTA
Engine: 350 TPI w/ extras !
ive got the hooker 2460's on mine, ive removed all the emissions crap because its not part of the years test here in the UK on cars over a certain age, and its also got a stainless exhaust system with no CAT and it goes great !
i had some running problems lately but ive got it running much better now, the only SES code ive got now is a problem with the burnoff function on the MAF, but thats due to some crappy wires
So you should be good.
