Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
SSBC A181 Dual-piston caliper upgrade
Old 08-15-2015, 01:15 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I bought this from Jegs, assuming it would magically make my brakes better. I was wrong, I wouldn't even put my car on the street with it.
You cannot put these on without an addition of a $600 or better Master cylinder. Factory Master Cylinder not compatible, even if it's in perfect working order. I found this out after contacting both Jegs & SSBC Tech support lines.
Now I'm not saying anything negative about this caliper assembly, what I'm saying is if you want to use its full potential you need more than just this $400 assembly & drilled/slotted rotors like I bought to make it work. Installing only these calipers, pads & rotors will be far worse than the factory brakes.
Old 08-16-2015, 01:51 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: SSBC A181 Dual-piston caliper upgrade
Wilwood makes a single piston or if you got to have them 2 piston direct bolt-on billet aluminum caliper set. You can get them in black red or polished finishes shipped to your door for under $380.. This is a direct Bolton her all non 1le Camaros in the third gen.. they also dropped about 6 pounds off your brakes.
Old 08-16-2015, 02:52 PM
Axle/Gears: 4.10:1
That's a nice looking set up! What happened in my case with the SSBC kit for some reason or another the pedal was very hard. I had my phone resting nicely on the passenger seat, I couldn't even make it go flying off the front into the leg-room as I slammed the brakes on! If I can make my cigarette lighter fly out of its socket to the back seat from a launch, my braking has got to get better.
Booster/vacuum checked out good. Again, not saying anything negative about the calipers, they may be great if given all the right components to work with! But I just don't have the $$ to make it reach its full potential. Oh well. I'll keep the drilled/slotted rotors and add new factory single-piston calipers & pads for now.
Old 11-12-2015, 07:26 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
What was wrong with the ssbc calipers?
Old 11-12-2015, 09:57 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This is a good example of Pascal's Principle. The SSBC caliper probably has different surface area than the stock single piston caliper.
The piston sizes in the master cylinder and caliper are sized to work together to provide the clamping force necessary to slow the weight of the car.
http://www.grc.nasa.gov/WWW/K-12/Win...principle.html
Old 11-13-2015, 12:44 PM
Axle/Gears: 4.10:1
Nothing wrong with it, just not compatible to my application.
Old 12-20-2015, 02:52 PM
KITT1983's Avatar
did they say what applications is it good for ?
Old 01-02-2016, 05:41 PM
Axle/Gears: 4.10:1
Sorry for the delayed response, but no he didn't tell me. They just said in addition to the calipers & Rotors that I bought, you'd have to buy the Master Cylinder which was not in my budget. So essentially, a 3rd gen with that Master Cylinder he speaks of I would assume is the right application.
Linson
09-25-2021 07:55 PM
BADNBLK
Brakes
10-06-2015 02:51 PM
the_hamturdler
09-30-2015 12:50 PM
Zell1luk
09-29-2015 10:36 AM
dbrochard
09-25-2015 04:56 PM
Quick Reply: SSBC A181 Dual-piston caliper upgrade
