Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Power window conversion kit off Amazon?
Old Dec 11, 2018 | 02:29 PM
ChelseaHere's Avatar
Car: 86 Camaro Sports Coupe
Engine: 383 Stoker
Transmission: 700R4 transmission
Hi all.
Has anyone tried this kit off Amazon? I'm thinking of adding power windows to my 86 sport coup. I was concidering adding one off a parts car that already has factory power windows... But I though this would be best and cheaper.
Old Dec 11, 2018 | 03:51 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Power window conversion kit off Amazon?
Cheaper being the operative word here. It is unlikely this will work as well and as long as GM window regulators. It would probably be easier to swap in the regulators and window/door harness from another car and add it into your car than to try and make that work. GM already made everything you need, you just have to pull it off a parts car and put it in yours..... regulators, harness, shifter plate, and switches. If you are also so inclined, you could do the "relay upgrade" and/or just increase the wire size in the GM harness. That is what I did when I tore my car apart. I cleaned all the window tracks, re-lubed them and replaced the factory wiring with 10 gauge from the switches to the doors, since I already had the wire. Now they work better than any other GM door I have ever seen new. Another potential upgrade is the "Window racer" from G-body parts, it increases the voltage to the window circuit, so when you operate the windows, they go a lot faster
Old Dec 11, 2018 | 04:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I believe you can get the complete wiring harness from Hawks.
you might want to post a ad in the classifieds section here.
https://www.hawksmotorsports.com/reg...r-r-or-l-used/
Old Dec 11, 2018 | 04:06 PM
Engine: 383 Stoker
That link, does all the parts I need come in that? What part would I need to lube?
Old Dec 11, 2018 | 04:08 PM
Engine: Lb9
Transmission: M20
You should call hawks, the harness would be separate.
or ask this member how much it might be if they put together a kit for you.
https://www.thirdgen.org/forums/member.php?u=152779
Old Dec 11, 2018 | 04:22 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Doesn't come with the motor either. Better off getting everything from one person from the classifieds or go to the JY yourself and get what you need
Old Dec 12, 2018 | 08:59 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
It is a lot of work to make manual windows electric, and or find doors & switch them, etc...
A friend and I had installed many aftermarket electric window kits back in the day and they worked great.
Brand name was Spahl (if my growing up in the 80's memory still serves me
Find a quality kit, be sure to clean and lube all the parts in the manual door tracks, etc...
My firebird had electric windows, so I did put the proper parts in, but had it not, I would go this route absolutely from my experience with kits like this from Spahl.
Rafael
Old Jan 4, 2019 | 05:47 PM
Engine: Lb9
Transmission: M20
Thirdgen ranch has a kit on sale now.
Tootie Pang
Nov 27, 2017 06:08 PM
aph415
Wheels and Tires
Sep 23, 2013 10:02 PM
BlueZee28
Jun 15, 2011 09:40 PM
mackjar66
Aftermarket Vendor Review
Mar 4, 2011 02:38 PM
