Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
ebay ?'s
Old Nov 12, 2006 | 07:48 PM
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
ebay ?'s
would yall trust ebay engine internal parts?
Old Nov 12, 2006 | 08:35 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Are we talking new or used parts? Who is the vendor?
For used parts, anything mechanical that is used is a gamble.
For new parts, check the seller's feedback and how long they've been selling to see how satisified customers have been.
Old Nov 12, 2006 | 09:25 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I bought my SCAT 4340 crank over Ebay and had it checked at the machine shop before I installed it and it was perfect! they said it was very balanced and didn't require that much more to get it perfectly balanced. You really have to look at their feedback though!
Old Nov 14, 2006 | 01:49 PM
84transam78239's Avatar
Car: 1989 Firebird formula 350
Engine: L98 long tube headers BBK TB
Axle/Gears: 3.73 positrac
it really depends on who you buy stuff from, ive had really good expereinces with CNC motorsports.
but i have bought over 1k in engine internals including
eagle crank
RHS heads
Comp cam
Lifters
Rockerarms
pushrods
and eveything is brand new and balanced and perfect
Old Nov 14, 2006 | 03:04 PM
86t/a owner's Avatar
Car: 86 t/a
Engine: 383 sbc on nitrous
Transmission: Th350 with trans brake
Axle/Gears: 9in ford
I also delt with Cnc-motorsports on ebay and off his site, clint is a great guy to work with and has some great deals.
my eagle crank rods, pistons rings and flex plate are from him plus a few other things.
Nathan
Old Nov 14, 2006 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it really depends who you buy from, wether the part is new or used, and whay brand the part is.
Old Nov 14, 2006 | 08:24 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Never buy used internals always buy new! Ebay is a great place to find new parts from real parts dealers all of the U.S. But do yourself a favor if your going to buy internals make sure they say they are all ready balanced!
Old Nov 18, 2006 | 04:54 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Another major thanks to CNC Motorsports, I got 1.6 roller rockers from them and they were amazing. They're actually CNC'd rockers I was impressed; about 1000 miles on my motor so far with no issues whatsoever.
Old Nov 18, 2006 | 06:58 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I was looking at some used pistons that the guy said were sent to the machine shop and cleaned and rebuilt
first of all how do you rebuild a piston and second of all the closeup picture of the piston showed the wire brush marks on the head of the piston.
I guess some to the people would go for a set of pistons and rods for 40 bucks but you have to be careful
Old Nov 20, 2006 | 12:28 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
I also got my Scat crank from CNC Motorsports, good deal everything was perfect. I second not buying used internals from ebay-even if you get them for cheap, shipping and possible repair costs will kill you. However, you can score on new parts from reputable vendors on ebay.
Old Nov 20, 2006 | 01:22 PM
jamon8's Avatar
Engine: 350 tpi
I bought an 081 head because I ported through a water jacket
I also knew what I was in for and expected to have to overhaul it completely.
it is not a good idea to buy a part like a block or a head or a crank without going into it with the idea that it will spend some time in the machine shop or worse have a crack in it and become a wheel stop
Old Dec 11, 2006 | 10:23 PM
ScatStroker's Avatar
Buying used parts is a gamble anywhere, ebay is no different.
For new parts it can be hit or miss - Do you know EXACTLY what you need? If you already have part numbers and just need a price then ebay is fine. If you need questions answered, an odd combo or special order part I would highly recommend you actually speak with someone.
Ebay is a listing service not a tech source, buyer beware if you don't know what you're buying.
As for balancing you'll get what you pay for most of the time... Do you want a stock type balance or do you want a precision race balance?
If a couple grams of variance on each component and a few grams of total variance is 'close enough' for your build then a standard balance is fine. The kits we order pre-balanced from Eagle, and the VAST majority of kits you'll find on ebay are all done in that manner. They take a set of rods and a piston, take 1 of each of their weights and balance the crank to that bobweight. The factory variance between pistons, pins and rods is the 'accepted' variance in their balance. Different shops have different tolerances but most stock type balances are ~5g as 'acceptable' on the crank.
If you spec a full balance, and generally more expensive, the shop is going to weight match the rods to eachother and then the piston and pin assemblies to eachother. This eliminates the variance in weights between parts. They then balance the crankshaft to this exact bobweight, generally within 1g or .5g, depending on the shop.
Persoanlly I'd rather do my own balances but if you want cheap, and generally "good enough", then a pre-balanced assembly might be for you.
$.02
Brian
www.adperformance.com
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
GageBrand
Oct 22, 2015 02:30 PM
okfoz
Oct 13, 2015 02:19 PM
