Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
https://bigbrakeupgrade.com/
Old Jul 28, 2021 | 04:32 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Great experience. Good guy, very knowledgeable. I almost pulled the trigger on LS1 brakes. Then Hawks came out with the 17" replica wheels. So I was able to throw even larger brakes on. I went with the C6 brakes. I have lower vacuum do to my large cam. So the stock brakes sucked even worse than they normally do. It's night and day with this upgrade. I'd say the braking is 90% better and I am able to lock up the wheels again. I still throw the idea around of going hydro boost, but I don't feel I need it nearly as bad now.
Some before and after's:
Old Jul 28, 2021 | 09:14 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
Re: https://bigbrakeupgrade.com/
What was the damage on the upgrade? All inclusive bolt on kit? Fills the wheels nicely. On the "to do" list...
Old Jul 28, 2021 | 09:48 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Same here, this might be my winter project but I will likely go with LS1s up front to keep my oem GTA wheels. I talked to Scott and supply issues are limiting some of his kits. This seems like a great upgrade for these cars.
Old Jul 29, 2021 | 02:48 PM
Car: 1988 IROC-Z
Engine: 427 SBC
$975.00 – $1,558.00 Depending on things you want to upgrade. Drilled/slotted rotors, stainless brakehoses, hub material...etc
Old Jul 29, 2021 | 08:42 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Yep, had a fantastic experience with him many years ago.
Old Jul 29, 2021 | 08:45 PM
Mine came all assembled and heavily saran wrapped.
Old Nov 29, 2021 | 07:26 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
That's a sweet set up!
Definitely will keep BBU in mind.
Old Nov 29, 2021 | 11:07 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Top notch service and Scott is a standup class guy. I recommend him to everyone.
Old Dec 2, 2021 | 08:21 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I have to say I like the C6 setup! but the LS1 isnt a slouch either, stock is F-body is 10.5"x1"? IIRC and the LS1 are 12"x1.25" which is a nice increase IMO and I like the price
Old Dec 5, 2021 | 01:28 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've used bigbrakeupgrade.com multiple times. Scott is a great guy who knows his stuff and produces a great product for a reasonable price. I put 4thgen fronts on one car and C5 brakes on another, both were great upgrades and well worth the money.
Old Dec 6, 2021 | 06:38 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
yep solid service. I went with a slight DIY approach buying some bits and modifying my own spindles. Scott was more than happy to share pointers and other guidance; never too busy though I suspect he has a lot on his plate
Old Dec 16, 2021 | 07:15 AM
Abubaca's Avatar
Another vote for BBU, and another big thumbs up for Scott! He's a BIG help in being able to select the right product, both for performance, and what will work with the parts you already have. On my second LS1 front kit (2 cars) and I'm considering a c6 z51 upgrade here soon.
Old Dec 24, 2021 | 05:23 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Just spamming another picture. The 17" rims and C6 brakes are my favorite mods I've done on this car.
Old Dec 25, 2021 | 08:06 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
All shined up for the photo op!
The larger wheels and brakes update the appearance, without sacrificing the car's heritage. It's what GM should've done mid-generation. Looks like you painted the rear calipers black to match the new fronts.
Looks great!
Sherman Johns
Brakes
May 31, 2017 11:30 AM
85SILVERBULLET1
19
Jun 6, 2014 03:13 PM
Stevo
Members Camaros
51
Mar 10, 2008 12:01 PM
S!MON
Members Camaros
Jul 29, 2007 02:19 PM
zimmstoy
Aug 9, 2001 01:29 AM
