#'s for HSR @ thunderracing.com
Car: 88 IROC
Transmission: th350 w/ b&m shift kit
MY OBSERVATION= on the thunder racing website, part NO.61-91506201 appears to be a complete HSR set-up with 42pph injectors for $2414.99.
MY QUESTION= does the "575-670hp" indicated with that part number mean-
1.it makes that much HP bolted to a stock engine
2.it is best matched to an engine already making that range of HP
3.its capable of pushing that much HP with other mods as well (if so, what other mods would it need for those numbers?)
4.none of the above
4.none of the above
Well obviously #1 is false. I WISH i could just bolt it to my LO3 and get over 500hp LOL.
#2 I guess would be partially correct. The HP numbers they are giving you are based off of the pph of the injectors. Its saying the unit itself can support around this HP level, so if maybe you had a carb engine that made these HP levels, then yes this would match that particular engine if you wanted to go EFI.
#3 Yes it would be capable of pushing that much HP with supporting mods. Don't expect it to be cheap tho. Do a
, there are an uncountable number of engine build-ups on this site, with an uncountable number of combos.
, there are an uncountable number of engine build-ups on this site, with an uncountable number of combos. Joined: Jul 1999
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
, there are an uncountable number of engine build-ups on this site, with an uncountable number of combos.-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by skunkIROC
well that settles it! clearly the best performance mod is window tint
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
i thought it also kept a fresh supply of ATF/FBI fluid in the muffler bearings?
We tried upgrading our cars to HSR's, but for some reason they wouldn't bolt up to the 4.6 engines under the hood. I'll have to get back to you guys on that one.
-- Joe
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Car: 88 IROC
what internals did you upgrade to for those numbers?
i'm looking to upgrade atleast heads, cam, pistons, and install a HSR. i'm curious which combinations are giving people the best numbers.
i would do that OR start with the bottom end and go the 383 stroker route. i'd like to have some numbers and prices to match before i make a decision.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 92 Z28 Camaro
No that's N/A. I made 781.5 W/ a blower. check out my cardomain site at the bottom of my sig. page 4 has a link to the N/A dyno chart, look around 5800 RPM.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
481 on an engine dyno.. so with an engine setup for N/A 500 would be possible.. this gets fuzzy, what a part is capable of changes with the setup, is the hsr good for 500hp on a 350? Or just a 406? do you want 500 at the rear wheels or crank? What rpm are you willing to spin to get that power? Hydraulic or solid cam? etc. etc..
you would need to spin a 350 fairly high to get those numbers.
a 383 with good flowing heads, a matched cam, decent compression and well setup bottom end with get you into the 450rwhp range with less cam and better driveability..
Then there is the intake.. While the HSR is a nice piece the total setup price of my converted supervic intake, plus rails, powdercoating, custom cam, ported and matched, was less than the hsr setup mentioned above..
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 82 Trans Am
Engine: LTX
I am hoping for the same numbers or better on my supervic LTx.. Though the cam is not as extreme as it could be, the big dollars are in the intake and heads.
Did you disagree with any particular point I made? I don't think I said 481hp is not fast. It is fast.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 92 Z28 Camaro
The HSR is a good economical replacement for the TPI. When I was approached to do this motor I insisted we use the HSR to show people it could make decent power with supporting hardware. I think we acomplished our goal.
Car: 82 Trans Am
Engine: LTX
https://www.thirdgen.org/forums/ltx-...nverted+intake
Though my intake preference is to take nothing away from 1 DwnCam's engine that is impressive and you certainly accomplished your goal!
86CamaroDan
Sep 29, 2015 10:08 PM
