Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Anybody catch this thing?
Old Mar 21, 2007 | 12:31 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Click ME
It seems like it might be a good idea I just wonder why he felt the need to have 2 throttle-bodies
Old Mar 21, 2007 | 12:37 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: Anybody catch this thing?
Yikes, that's wild. Maybe good for twin turbo apps?
Old Mar 21, 2007 | 12:43 PM
Car: 89 Formula
Maybe but why? the rest of it seems like an ok plan but why the 2 TBS
Old Mar 22, 2007 | 05:42 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Made by a good welder, not a good engineer.
The injector angle is horrible. Perhaps with a boosted application, it will atomize the fuel ok. n/a, that thing is gonna suck nuts. Stay away from it.
-- Joe
Old Mar 22, 2007 | 11:35 AM
Car: 89 Formula
Oh I'm not buying it I just had to say WTF?
Old Apr 27, 2007 | 08:17 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
-- Joe
Curious why you say that?
On the fuel note, it has been found that in many cases firing the injector "up" the runner will help it atomoze better than firing it with the runner.
NX did some tests using thier shark nozzles and found there was either no difference in output or they may have actually picked up a little by facing the nozzle up stream, and the theory is that because of the resistance to flow it forces teh fuel to atomize.
Old Apr 27, 2007 | 11:55 AM
Shagwell's Avatar
Car: projects.......
The biggest problem I see is that conventional 23 degree heads are never gonna flow enough to need two TB's. The idea was similiar to a HSR, but utilizing a much more racing oriented lower manifold. - Auction closed at $480, even if you were to throw the plenum away and build one for a single TB, not bad. - Clean job on the smoothed in airfoils too. The injector angle wouldn't be bad for an application needing that much manifold. If you were actually using that much air, you'd probably be running large enough injectors to have a stream instead of a spray of fuel, thus the angle could easily help atomization.
What early vette would have had 28# injectors? Especially being Multecs.
Old Apr 27, 2007 | 07:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
LT5 powered ZR1 from 90-95 maybe.
InfinityShade
Feb 21, 2016 01:29 PM
formula_novice
Sep 5, 2015 03:58 AM
someone972
Aug 30, 2015 12:52 AM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
