Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Anyone hear about Accel intake problems?
Old Oct 12, 2007 | 05:49 PM
Kawtipping's Avatar
Car: 92 Trans Am
Engine: 383 Stealth Ram
Transmission: 4L60
Axle/Gears: 3.42/10 bolt
Well, I have been looking into after market intake options (Multi-port style), and came across this bit of info. Someone may have posted it already, but I haven't seen it. Accel does not have anyone to make their intakes any longer. And as of right now their is no stock on the Super Ram...anywhere that I can find so far!! Looks like I get to start looking at other options like TPIS's set-up.
Old Oct 13, 2007 | 02:11 AM
Kurt04's Avatar
Re: Anyone hear about Accel intake problems?
This should really be in Alternative Port EFI Intakes. You'll find more info in there. If the Superram is in fact discontinued, you can look into other options, like you mentioned TPIS Miniram, or Holley Stealthram, or Various Single-Plane EFI setups.
Old Oct 13, 2007 | 08:32 AM
Kawtipping's Avatar
Car: 92 Trans Am
Transmission: 4L60
I really wasn't sure where to put it. Some of the topics/threads have labels that do not do their subjects justice. Like here...DFI...Accel even calls their set-up DFI (when you use their software anyways)
As for the intake, I don't think think it has been disco'd. They just have not found a source to make them yet.
Mods, please move this thread to where you think it should be.
Old Oct 13, 2007 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I moved the thread to the Alternative Port EFI Intakes board. The DFI & ECM board is more about the computer side of things.
RBob.
Old Oct 13, 2007 | 08:48 AM
Kawtipping's Avatar
Car: 92 Trans Am
Transmission: 4L60
RBob.
Thanks for the move. I just wasn't sure....that and I don't think I have made it this far down the tread list before
Old Oct 13, 2007 | 09:01 AM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
The Superram has been discontinued .
Old Oct 13, 2007 | 12:05 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Where did you get your info from
Old Oct 13, 2007 | 02:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I thought Accel was using the Edelbrock intake manifold.
Old Oct 13, 2007 | 03:36 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
According Lingenfelter Performance, the runners are the item out of stock, and as of about last May (2007), a casting facility willing/wanting to manufacture the runners had not been selected. I haven't called LPE or Accel recently.
Bill
Old Oct 13, 2007 | 05:09 PM
InsaneIROC's Avatar
Engine: 364 Ci Ls2
I saw it on this site some weeks back.
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
