Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
LT1 intake swap
Old Jan 15, 2008 | 04:02 PM
Olav's Avatar
LT1 intake swap
Hi!
I have started modifying a LT1 intake for my SB. Can i drill the water outlets in the rear?
Thanks!
Olav
Old Jan 17, 2008 | 02:44 AM
Olav's Avatar
Re: LT1 intake swap
Originally Posted by Olav
Hi!
Thanks!
Olav
Any?
As I see it will not make any diffrenence or am I wrong ?
Olav
Old Jan 17, 2008 | 01:12 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: LT1 intake swap
Any?
Olav
You mean drill the rear for the water fittings for the remote thermostat?
-- Joe
Old Jan 17, 2008 | 03:00 PM
Olav's Avatar
Re: LT1 intake swap
-- Joe
Thats what i mean...
Olav
Old Jan 17, 2008 | 04:49 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: LT1 intake swap
Olav
Yes, you have to, because if you run a new style throttle body, the cable arm crashes into the water fitting.
-- Joe
Old Jan 21, 2008 | 11:14 AM
BryOwnz's Avatar
Re: LT1 intake swap
what are the benifits of doing this swap? does the LT1 have that much more top end to go with the swap?
Old Jan 21, 2008 | 09:03 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: LT1 intake swap
Did you bother reading the 500+ threads on the topic?
-- Joe
Old Jan 22, 2008 | 08:22 PM
BryOwnz's Avatar
Re: LT1 intake swap
-- Joe
nah, i was just asking for some general information, wasnt even really looking into doing it, just curious
Old Apr 19, 2008 | 09:03 AM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Re: LT1 intake swap
ok lt1inntakes.com no longer around so where can I get one from already modded.someone pm me with one or info.
Old Apr 19, 2008 | 03:59 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 intake swap
https://www.thirdgen.org/forums/engi...-1-intake.html
Helluva a deal right there
Option B is to buy a miniram
Old Apr 22, 2008 | 09:02 PM
Wrenchp's Avatar
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
Re: LT1 intake swap
Or go with the LT1 and use an EDIS system.
That is what I am doing on my SBC for my RS.
Old Apr 22, 2008 | 09:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: LT1 intake swap
Let me know if you actually get that to work.
I've been wanting to hear from someone who actually has one working. Everyone else seems to get angry, and ends up selling it.
-- Joe
Old Apr 23, 2008 | 08:01 PM
Wrenchp's Avatar
Car: 1988 RS Camaro
Transmission: TH400
Axle/Gears: Stock
Re: LT1 intake swap
I will be using megasqirt to control it and my fuel. It seems pretty straight forward to do.
What problems have they been having with it?
Old Apr 30, 2008 | 06:41 AM
irocwagon's Avatar
Re: LT1 intake swap
ey I preciate the link pocket, I'm waiting to ive the intake now. already got a full lt1 t56 conversion but my other is a 383 tpi, seems to pull good up to 5000rpm then on its face it falls full exhaust with high flow cat, thinking ns bout ditching cat, we have no emissions, left on in case I sell it. headers also have air tubes drilled and welded on
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
