Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
trying to go EFI
Old Feb 8, 2008 | 05:14 AM
Bigwill92's Avatar
Car: 92 Camaro
Engine: cammed 357 with headers
Axle/Gears: stock
trying to go EFI
just need some input on what kind of EFI setup i should try to get for my 357 92 camaro that has TBI right now?it's too slow for me right now.plz lemme know what u would do.i have 3.73s in the back w/posi,aftermarket headers,exhaust,cat,t-5 tranny,and hardened pushrods.lemme know what else i can do to make my setup better with the fuel ratio.this TBI is what i think is really slowing me down.thanx a bunch
Old Feb 8, 2008 | 07:31 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: trying to go EFI
What are the cam specs? What heads?
-- Joe
Old Feb 8, 2008 | 08:01 PM
Bigwill92's Avatar
Car: 92 Camaro
Axle/Gears: stock
-- Joe
has a stock cam in it now.used to have a pretty aggressive cam but it ended up being the reason for a broken/bent pushrod.heads are stock 350 heads as well.
Old Feb 8, 2008 | 08:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
stock 350 heads as in L98 iron heads? stock cam as in stock L98 cam?
i happen to like my holley stealth ram for performance and price. With a TPI retrofit ecm/wiring harness, you can easily convert to HSR
Old Feb 10, 2008 | 03:25 AM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Bigwill92,
Orr89RocZ has a point the holly unit is a nice setup and if you wanted to port the heads and toss in a cam down the line you would already have the intake covered. It also has the advantage of being one of the best money spent/power gained ratio there is out there. I think the stealth is 400, the super ram (good luck finding one) will vary in price as its not in production anymore, mini ram is around 1300, and the first is 1000.
As an alternative, the first injection setup is a nice breathing unit. It is a ltr type setup so you would retain your low end torque. An easy setup for buckets of street friendly torque would be to get a set of 180 cc heads (or port yours over) with a good angle valve job/larger ports 2.02/1.60 then get a short duration cam to keep your power down low nothing more that 5500-6000 peak rpm. This way you don't wear out your valve train so fast and you'll have plenty of power to slay the usual around town suspects.
Remember every component in your engine has to work together to be efficient. it depends on where you want to you cars power range to be and how much money you want to spend.
Rabi C.
Old Feb 24, 2008 | 11:26 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Now why haven't I heard of this company or product before? This is exactly the kind of stuff I've been looking for. Grant it, the ECM isn't that great, but maybe with the EBL or something like that, it would be one hell of the bang for the buck set up.
I seriously wish I would have known about this before!
Anybody on here actually have one of their setups?
Old Feb 24, 2008 | 01:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i do believe there is a few ppl here with them, and some on corvette forum. I think 1989GTAtransam has a first base with moddified SLP runners that will bolt to the first base. He made 350whp before these mods so i think he will pick up
Old Feb 24, 2008 | 04:30 PM
onfire's Avatar
Car: 88 Formula 350
The thing that I like about the First setup is that it has a provision for an egr valve. This is the only option for places like California where smog inspection is strict. The only other option, as far as having an egr provision besides modifying the tpi, is accel's supper ram.
BBK is making a "turtle ram" type setup if you have the patience to wait. This will also have an egr provision.
These, that I have mentioned, are just the setups with egr. There is the miniram and the stealth like Orr89RocZ mentioned which are also great options in their own right.
Take your time and read the posts that people have up. There are many posts relating to each of these types of intakes (besides the BBK which hasn't been released yet) and their performances with particular cid/head/cam/rocker arm ratio combos.
Rabi C.
Old Feb 24, 2008 | 11:41 PM
Car: 91 RS
Engine: 350 TBI
Rabi C.
Yeah, I found a few threads about the FIRST in the TPI section and on CorvetteForums.com. I've been looking for an alternative form of EFI for about a year now. I have a bored out TBI and Edelbrock TBI manifold, but it is seriously hurting for airflow above 4k. And of course, like many people I live in an area with emissions. This eliminated most of the aftermarket stuff.
Even with the choking TBI stuff, I still managed 365 RWTQ on the dyno, so I can only imagine what a system like this would do.
Another appealing asset of it is that it fits under the hood and they supply all the electronics. It seems the only thing I would need to do to make it all work is pick up a good fuel pressure regulator and a small cap distributor.
Any idea on when the "Turtle Ram" is due out?
Old Feb 25, 2008 | 07:05 PM
onfire's Avatar
Car: 88 Formula 350
Gunny Highway,
No news on a specific release date. The thread is:
https://www.thirdgen.org/forums/tpi/...-setup-13.html
Check it periodically to see if there are any updates.
If you have to deal with smog checks then I would just go with either a first or a supper ram. In terms of installation, the first would be easier to bolt on. The supper ram does have its benefits such as a higher cfm flow compared to the first but really not by much. With porting the first can get up there too. So its up to you what you think. I have a supper ram now and going form a tpi to a supper ram, it does have more horse up top with the trade off of torque down low. I am running the 219 cam so with this setup it also needs gears to be either 3.42 or 3.70s. Just haven't decided yet on which shall be the one. Just my experience.
Rabi C.
Old Feb 26, 2008 | 12:34 AM
Car: 91 RS
Engine: 350 TBI
Gunny Highway,
Rabi C.
Well I talked to Ken (?) at FIRST and I think that might be the way to go. His full kit comes with everything but the regulator and throttle cable. I'll need one since my TBI ones isn't long enough. The only problem now, is that I live in an apartment, so I don't have a place to work on it. That means I'm going to have to pay for it.
Old Feb 29, 2008 | 11:35 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Everyone always forgets that professional products has an efi kit. They just converted the Hurricane single plane intake to EFI and give a fuel rail kit. Am i still going to be the first to try it?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
rubyred88
Sep 17, 2015 02:19 PM
