Tip: HSR swap & upper radiator hose
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I recently completed the HSR swap. I installed Mr Gaskets 2661 water neck which takes a 1 1/2" ID hose. The radiator upper connection is 1 1/4". I found an upper radiator hose at Advance Auto Parts P/N E71029. It has 1 1/2" water neck ID and 1 1/4" radiator ID... I am a happy camper right now.
I had tried the Summit Racing adapter hoses stuff, but blew off the upper radiator hose and drop the anti-freeze all over the place. Not to mention, severly over heating the motor.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Tip: HSR swap & upper radiator hose
Yes, that Summit hose adapter is a really hokey set-up; I ran it for two days and noticed the radiator hose was slipping out of the adapter section. I found a flex hose similar to the one you are using and hose-clamped it to the accessory belt guard for additional support. I LOVE my HSR
Bill
Bill
Car: 84 Monte Carlo SS
Engine: 408
Transmission: 700-r4
I am pretty sure that I just used my upper radiator hose from a 1984 Monte Carlo SS and had no problems (using a F-body aluminum radiator).
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
I used a Mr gasket chrome water neck and put a little dielectric grease on the hose and it worked perfect... until the hose blew off cause I didn't rough up the chrome . Doh!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I beleive I used a TBI upper hose as well as a TBI neck with fittings in the sensor holes.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Bill
Bill
I don't think anyone who has actually driven a HSR with an open mind will knock it. Bang for the buck, BEST intake upgrade out there for TPI cars. I'd consider the LT1 intake 2nd, but that requires modification, and the remote thermostat is kind of clunky. Minor low end loss, for a decent peak boost and a massive extension of the power curve.
Car: 1988 IROC-Z
Engine: 427 SBC
I got the hose. It didn't fit well. I had to cut it a bit. Did you?
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
1992 Trans Am
May 10, 2023 07:19 PM
