I need need to upgrade my Intake setup or will this stuff work for what I want?
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
I am buiding a 383 stroker motor for my 92 z28, its a 96 vortec 350 block. I am gonna use a forged crank, rods, pistons, I already have the vortec intake, stock vortec heads, SLP ported runners, ported plenum. 52 MM throttle body.
I am going to be changing to AFR vortec 190 heads, and a bigger cam with dual pattern cause I plan to spray it also.
I want to make 400-450 horsepower at the wheels. Can my intake, runners, plenum, throttle body handle it or should I change to the holley stealth ram and such? How much can they handle?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: I need need to upgrade my Intake setup or will this stuff work for what I want?
Axle/Gears: G92
Car: 82 Z28
Transmission: T400
The TPI shootout link is no longer working but all the TPI versions maxed out below 5K whereas the with a MR / HSR ran over 6K
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Man swap to the HSR you wont be sorry....
Car: 92 rs
Transmission: 4L80E
well the main problem you'll have with that intake.. is i dont believe AFR makes a head for the vortec intakes.. i might be wrong.. its been along time since i looked into them... but you wont get much outa a tpi setup as far as hp goes.. ppl can say what they want.. i know from personal experience that the HSR at least with my setup has pulled to 7 grand many many times... without so much as a hesitation or loss of power that i can feel.. unlike tpi or a long runner setup.. once u get to roghly 5000-5500 its like hitting a wall.. they just dont like to pull. Which will really limit a good combo with the afr heads... look at it like your engine needs the air supply of a fire hose.. and u give it a little straw... just choking it off....
Axle/Gears: G92
http://www.airflowresearch.com/index.php?cPath=24_117
The HSR is just so damn expensive 3500? I mean holy crap...
Axle/Gears: G92
Car: 82 Z28
Transmission: T400
Your on the wrong page.
You already have a computer , TB and wiring
Intake $325
http://www.summitracing.com/parts/WND-7540/
Fuel rails $185 -$240
http://www.summitracing.com/parts/HLY-534-185/
http://www.summitracing.com/parts/HLY-534-186/
Intake $325
Axle/Gears: G92
Intake $325
Intake $325
My other question is I was searching about the ProRam and couldn't figure out if they would work with vortec heads.
If the stealth ram is the only one that will work with vortec heads then won't I be maxing the intake out with the heads and cam before I even spray it?
Car: 92 rs
Transmission: 4L80E
the stealth flows 275 per port im running this setup with 200cc intake dart platinum's and im haveing no issues other than breaking tranny's cause 700r4's suck but thats a different thread..lol
Axle/Gears: G92
I also want to eventually procharge the car.
Car: 92 rs
Transmission: 4L80E
i was lookin at turbo's but untill i get something that can handle the power im makeing now.. i didnt see much since in it...lol
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
400-450whp on a 383 is no easy task. I'd skip the vortec thing and just go straight to HSR mildly ported and AFR 195's minimum or Profiler 195's if they are a 1205 port size.
I'd really like to see 210 heads with a 1206 but that will depend if you can port the HSR to 1206 gasket size. Some HSR's can be ported there but old castings cant. Depends on what you get.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Fast355
Dec 2, 2016 06:33 PM
