Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
Throttle cable setup for an LSx throttle body
Old Jul 16, 2011 | 10:26 AM
83 Crossfire TA's Avatar
People running round, LSx style throttle body what are you guys doing for a throttle cable setup? Can a stock TPI cable be made to work or are you running something else? How are you routing it?
Old Jul 25, 2011 | 12:17 AM
Re: Throttle cable setup for an LSx throttle body
Anyone?
Old Jul 25, 2011 | 12:33 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
In this link couple people talk about what to do for the cable
https://www.thirdgen.org/forums/alte...-xt-parts.html
Old Jul 25, 2011 | 05:16 AM
88gunmetalgta's Avatar
I have a cable from a minivan (venture/silhouette). It has the big lug for the LSx TB, the same size square clip as the TPI, and it fits the gas pedal well. Its got a spring in it down by the gas pedal tho, and that doesn't get along nicely with the heavy LS1 return spring, I just haven't gotten around to eliminating it yet. The bushing/grommet where it goes through the firewall is smaller too. Not a big deal, just gotta seal up the hole.
Its just about the perfect length for my application, which puts the throttle body between the carb pad and the water neck.
I'll snap a couple pics if I remember.
Old Jul 25, 2011 | 09:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My single plane with intake elbow puts the throttle body out further than TPI so the stock cable wouldnt work. Plus the LSx TB linkage is on the other side of the TB than it is with TPI TB's.
I ended up buying the matching year GM fbody LS1 cable for my throttle body and putting that one in. Works perfectly. Just had to fab a bracket to mount the cable at the TB since my custom elbow didnt have a connection for it.
Old Jul 29, 2011 | 09:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Never done it myself but Id say use a stock 98-02 fbody cable on a car without traction control??
Old Jul 30, 2011 | 09:09 PM
huh, thanks for the link, but they talk about a blue or brown spring, the one that I have has a yellow one...
Old Aug 2, 2011 | 11:26 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
this is what all of us lsx swappers are using, works pretty well. i know your setup's a little different, but this is a good starting point
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
