Alternative Port EFI Intakes This board is for tech discussions and questions about aftermarket port EFI such as the HSR, MR, SR, BBK, FIRST, etc.
HSR bracketry
Old Mar 17, 2012 | 09:07 AM
87SLEEPER's Avatar
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
HSR bracketry
Currently on my engine swap on another thread and I'm using a stealthram. I have already noticed that my alternator needs a different style bracket to mount back up with my new manifold. Any suggestions? Also are there other brackets I will need? If this has already been posted please paste links.
Old Mar 18, 2012 | 06:20 AM
87SLEEPER's Avatar
Car: 1992 RS B4C
Re: HSR bracketry
http://www.summitracing.com/parts/SUM-G4017/
will this work?
Old Mar 18, 2012 | 10:45 AM
87SLEEPER's Avatar
Car: 1992 RS B4C
Re: HSR bracketry
anyone??
Old Mar 18, 2012 | 12:14 PM
Re: HSR bracketry
Those look like the same thing you've already got (stock), just, with "chrome" added so that they'll look like crap in about a week.
Easiest thing to do might be to get a later-model serpentine system, since those don't require for anything to bolt to the intake at all.
Old Mar 18, 2012 | 03:13 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Re: HSR bracketry
They are different than MY stock bracket because I have TPI and I believe the ones from summit are for standard intake manifolds. I read elsewhere that a bracket from a carb or TB 3rd gen would work. Are they just a standard sbc bracket or are they specific to camaros? It seems easier for me to just order the summit one for $14 and sand it then paint it black to match the rest of my hardware than hope to find one in a junkyard with the right type of motor.
Any more thoughts?
Old Mar 18, 2012 | 03:55 PM
Re: HSR bracketry
I didn't realize that the bracket was different for that one application... it stayed the same from the mid 70s until end-of-life for carb intakes. From 69 to whenever (about 72 or so) it went to the pass side water outlet bolt which looks like it wouldn't work with that intake.
That other bracket, the carb one, goes to that bolt hole you can see in your HSR pic in front of and to the pass side of the water outlet; so in that case the Summit one would work, or one off of a carbed car.
I sure wouldn't get a "chrome" one though, unless nothing else was available; in which case I'd sandblast the "chrome" off and paint it. But that's just me, I DETEST rusty parts that are all shiny around the rust, so the rust stands out so plainly.
Old Mar 18, 2012 | 09:18 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: HSR bracketry
We sell that alt bracket where I work. I was having the same prob and I thought they was the same too I don't want chrome but that's all they have I going to try the smoke paint stuff. What u do for your fuel lines.
Old Mar 18, 2012 | 09:51 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Re: HSR bracketry
I haven't gotten to fuel lines yet. Prolly won't be for another 3 weeks or so. Feel free to check out my thread "357 stealthram build" and I'll be sure to get some good pics for ya. If you beat me to it then let me know so I can check yours out.
Old Mar 18, 2012 | 11:04 PM
Sojer's Avatar
Re: HSR bracketry
Ok I'm on 300hp 305 build on motor swap I got my intake on and dizzy in spark plugs and wires in headers but that's it oh injectors who u go for tuning
Old Mar 19, 2012 | 02:29 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: HSR bracketry
I had to grind a slot in the coil bracket on my iroc. There is a ridge on the stealth ram between the bolt holes of the coil bracket and it cannot sit flush against the intake in its factory position on the back two intake bolts on the passenger side.
Old Mar 19, 2012 | 08:40 AM
Sojer's Avatar
Re: HSR bracketry
I did too
Old Mar 19, 2012 | 07:01 PM
87SLEEPER's Avatar
Car: 1992 RS B4C
Re: HSR bracketry
Thanks for the coil pics. I had started mine the other day and got it mounted today. As far as tuning I was gonna call this guy http://www.lt1pcmtuning.com/about/ and do the email tune. I have a autoprom but I am really new to using it. I think though if he writes up a code to get me moving I can figure out how to burn it and bring it to a dyno for some better numbers.
https://www.thirdgen.org/forums/engi...ram-build.html
Old Mar 19, 2012 | 09:21 PM
Sojer's Avatar
Re: HSR bracketry
I cut the factory hard fuel lines clean them up and put the rubber hose on then u will need a line connecter for 5/16 to 3/8
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
